Originally posted by RioRico Were longer lenses actually tested? Where can we find the protocols and data?
Yes. Besides my own quick test at 300mm, I explicitely referred to the tests carried out by German magazine ColorFoto carried out in 2008 and 2010.
Their testing methodology was well documented. It is on par with the work by P. Smith (i.e., sub pixel accurate edge blur widths based on N=10 samples, static and blur w/o SR as reference), except that they used 23mm and 130mm focal lengths (35mm and 200mm equivalent for 35mm format). Additionally, they seem to be the only one who developped and built a shake test device which simulates the human tremor pretty well (no pure oscillations). This makes their tests very reproducible.
My blog contains the 2008 result. Here, I now additionally provide a scan of the 2010 result for 130mm:
The blue bar is the tripod reference, the red bar is without SR, thze yellow bar is with SR. "
Kantenbreite" means "
edge blur width" and "
Belichtungszeit" means "
exposure time".
It is obvious that the effect of SR at 1/50s and 1/100s is small and at 1/200s is not significantly different from zero. I.e., SR cannot render the 1/200s result as sharp as with a tripod. Of course, this would be desirable and some other tested devices could do exactly this (or at 1/100s or even at 1/50s).
Originally posted by imtheguy As a long range shooter like Wheatfield I don't want to believe the extrapolation is true but I sure can't dismiss it either. [...]
If I can produce repeatable results I will post them here next week.
I found it hard to swallow as well. I always thought "my" SR would do better for long range tele photography. But I couldn't but post my findings as ... as I found them
I am really keen to learn about other tests which tell a different story.
Untill then, I find it reassuring that slower than 1/100s is a useful domain for tele photography as well and that some other cameras/lenses have a similiar characteristics.
