07-22-2014, 10:08 AM   #1
hinman's Avatar
Help: jammed Spotmatic, exposed film on counter 5
My spotmatic was on count 5 and its film advance is jammed while the shutter has no action upon pressing. So last night, my first reaction was to wind the rest of the 36 roll and open up the back door to see if anything unusual or trivial to fix.
DSC07506
I should have gone to this fantastic thread of discussion for the solution, I opened up the base plate of my Spotmatic and saw the problem exactly as illustrated in the photos in the link. A push on the lever enabled the shutter release.
Jammed Spotmatic?
And now my Spotmatic is freed from the jammed shutter.
Question: Can I re-use the roll in loading it in the dark and advance the film to the 6th counter?
Cheers,
Hin
07-22-2014, 10:23 AM - 1 Like   #2
QuoteOriginally posted by hinman Quote
Cheers,
Hin
You should be able to reload the same film as you would normally load, then advance to the 7th frame by keeping the lens cap on and firing the shutter normally.
The part of the film that gets exposed to light while loading was already exposed the first time you loaded the film.
07-22-2014, 10:49 AM   #3
hinman's Avatar
QuoteOriginally posted by Swift1 Quote
Much thanks!
Hin
advance, counter, film, roll, shutter, spotmatic
H1A Jammed Film Advance jswillems Film SLRs and Compact Film Cameras 9 08-13-2014 01:55 AM
Film type dial / exposure counter control dial. keeping on 220 elephantvanishes Pentax Medium Format 6 10-15-2012 10:41 AM
645 film counter Halco Pentax Medium Format 6 06-28-2010 05:41 PM
shutter jammed on K10D - help! pszilard Pentax DSLR Discussion 2 01-30-2010 09:06 AM
Film advance jammed on KM Kmman Film SLRs and Compact Film Cameras 22 09-25-2009 06:12 PM
All times are GMT -7. The time now is 11:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
