11-22-2014, 10:20 AM   #1
Power Zoom - how?
I've just picked up a Z-50p which seems to work, mostly to use with my FA-J 18-35mm (as it can control the aperture from the body) but also because I have the PZ 28-80mm zoom.
However, I can't find a manual for the camera anywhere. I've worked out what most of the buttons do but I'm struggling with the power zoom functions (other than the obvious one of clicking the zoom ring forwards to activate it). What am I supposed to be able to do with the button and slide switch on the side of the lens? Pressing the button seems to make it auto focus (just like half pressing the shutter) and if I set the switch to A then half press the shutter the lens zooms on its own, as well as focusing.
11-22-2014, 10:37 AM   #2
Summary of PZ functions:
Pentax Lens Power Zoom
This manual covers it (note the manual is split into 2 pdfs, the break is right in the middle of the zoom stuff looks like):
Pentax PZ-10 manual, user manual, free instruction manual, pdf manuals
11-22-2014, 10:49 AM   #3
Thanks for that, if anyone else is trying to do the same thing then the Z-50p uses the rocker dial/switch behind the shutter button instead of the +/- buttons, but is otherwise the same.
11-26-2014, 04:07 PM   #4
johnha's Avatar
As far as I'm aware the only bodies to use the PZ 'P->A/S' switch on the lens were the PZ series where they setup the Zoom clip and Image size tracking, modes. IIRC the zoom effect and 'portrait' zoom modes were driven completely by the camera. The portrait mode allowed the user to specify either a 'full length' or 'head & shoulders' portrait and used the AF distance to calculate & drive the correct focal length.
This switch/button arrangement is fragile and often breaks (the curved plastic cover holding them on to the lens break) and are then taped up.
On film cameras running Lithium batteries, these functions aren't worth the power drain - but they do make the zoom rings of the FA lenses feel a bit 'gritty' even in manual zoom mode.
11-27-2014, 04:37 AM   #5
Well, mine works. I bought the lens mint but minus the switch, then replaced the missing parts with spares from a seriously mangled example that I'd previously bought intending to repair (then found that FA lenses aren't as simple and solid as K or M lenses!) I managed to reattach it with a tiny dab of gel superglue, you can't see any difference and it doesn't seem to have harmed the lens. Everything lights up and works. The powered zoom part works on some of the DSLRs, minus the special effects.
I was wondering how the portrait mode was supposed to work, having figured out the image size tracking and zoom clip features. Will have a play and see what happens.
02-09-2017, 11:41 PM   #6
p38arover's Avatar
I have PZ-1/Z-1 and wondered if the image tracking is worth playing with. I've been tempted to buy a power zoom lens just to play.
Has anyone actually tried the image tracking?
button, half, lens, power, shutter, switch
Power zoom and k30 Spodeworld Pentax K-30 & K-50 4 06-01-2013 05:44 AM
moving power zoom Gabriele Lunardi Visitors' Center 5 05-17-2013 09:18 PM
How to power 540FGZ flash with Alienbees Vagabond mini II portable power? shadowbecomeswhite Flashes, Lighting, and Studio 2 07-25-2011 07:17 PM
Zoom/Power zoom on flashes: why? hray Troubleshooting and Beginner Help 11 03-03-2011 03:02 PM
How much zoom power do I need. Dekka Pentax SLR Lens Discussion 10 07-31-2008 02:18 PM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
