Originally posted by AquaDome What happens if you wait for 30 or 40 seconds? If the light sensor is not seeing light, the shutter will stay open for the maximum duration. Wait it out for a minute and see if it completes.
No luck unfortunately
Waited for a few minutes but didn't complete. Only when i move to mode switch to 100x or L does it complete.
---------- Post added 04-22-15 at 08:22 PM ----------
Originally posted by Auzzie-Phoenix Could be a bad solder joint, or a dirty contact. Could also be a problem with whatever mechanical device moves the curtain itself. If for instance the curtains worked via motor that moved one side, and springs that acted to pull the other side, then I'd look at the springs as well (I know I'm probably not describing this in a way to make much sense...). Does curtain #2 move freely, or perhaps it needs lubed somehow? I know nothing of the ME/ME Super, so all I can do is speculate on possible causes at this point. If your problem is electrical in nature, then good chance you can track it down using a multimeter.
Thanks Auzzie. I was thinking mechanically it is ok, as it seems all ok on bulb and 100x (and on auto without a battery). I believe curtain #2 is ok as everything completes when on 100x. Im guessing whatever is supposed to be electrically triggered when the selected shutter speed timer ends is not being triggered. I do have a multimeter, just not sure what i should be testing or where i should be looking
