Originally posted by vicool Yeah just some basic features and the image quality, ease of use... Those are both basic so it's harder to compare, I just have 50$ so I much choose 1 of them
I think the posters here answered most of your questions, didn't they?
For the image quality, it depends more by the lens than the camera itself, if your budget just for the body or also for the lens?
For ease to use, as they already explained the xr1000-s is a more sophisticated camera with aperture priority, probably for a beginner I would recommend a simpler all mechanical camera like the Pentax K1000 or even better a Spotmatic F with Takumar 55mm 1.8, you should be able to find it in your price range: all you have to do with these cameras is to set the ASA of the film you use, set the shutter speed, turn the aperture ring until the needle is horizontal, focus and shoot, plus being mechanical they are always reliable and you can use them even if you run out of batteries.
For the lenses I don't have direct experience with Ricoh glass but I heard their 50 mm f1.4 is very good (expensive, tough), but being K mount you can also use Pentax lenses, the original K1000 came with the K 55mm f2 that is an excellent lens, the problem is that it's not easy to find one, most of the K1000s produced in HK came with the M 50 mm f2 and I'm not a fan of that lens, as well as the A 50 mm f2.
Still being K mounted you have many alternatives.
