09-01-2015, 12:48 PM   #1
A few questions about the p3n and how to improve my lenses aperture ring
Hi people
I've just picked up a couple of p3n bodies, both of them seem to be working really nice but I have a question regarding the films I can or can't use.
As the ISO the camera uses is the DX coding from the film, the camera specs mention that only film up to 1600 asa can be used. ¿What happens if I want to use 3200 film? I know I can use a digital camera as a light meter, but is there anyway I can trick the p3n to make it work at 3200?
Also, I have a 50mm 1.7 lens that used to work really well, but after living overseas for a while now the aperture ring is really rough, I have to apply quite a bit of strength to make it change the aperture. Is there any way I can fix it? Oil or any other lubricant?
Thanks in advance
09-01-2015, 01:21 PM   #2
Does the p3n have exposure compensation? That would be the way to trick it. If not, you're going to have to do the math in your head.
09-01-2015, 01:36 PM   #3
gofour3's Avatar
QuoteOriginally posted by JordiTrenzano Quote
Hi people
Thanks in advance
Unfortunately all the "P" Series cameras have DX coding, but no manual ISO override. This means you can't push/pull any film or use non DX coded film, unless it is 100 ISO which is the default for non DX film.
The P3/30's also do not have exposure compensations, so that rules out that as a option.
As for the 50/1.7 I'm assuming it's the "A" Series? if so that is a known problem with this lens and yes you can get it fixed but it's a design flaw so it could happen again.
Phil.
09-01-2015, 04:17 PM   #4
Jordi Hi!
I also have a couple P3N, or P30n as they are called here. Really nice (undervalued) cameras with easy to use controls, and the exposure is really great.
I know it is said that it is not possible to use the "push" and "pull" with these cameras. I do not really agree with that.
It ought to be possible to consistently over- or under-expose all the pictures on a roll, to achieve this. I have never used this technique myself, but it should work. And it's simple too; In manual mode, adjusts the aperture and shutter speed for proper exposure. Then I think it seems easier to change the shutter speed to over- or underexpose.
The difficulty is probably remember this for later photo sessions (if you do not shoot the entire roll at the same time, of course). A note on a sticker on the back camera would be handy.
Do not know how the camera responds with a DX-coded ISO3200 roll of film. Probably sets itself in ISO100. To achieve ISO3200 from 100 would be underexpose 5 steps, not very praktical. It is clearly better to use DX ISO1600 film and underexpose one step.
Good luck!
/ Roger Lindholm
09-01-2015, 04:46 PM   #5
ChrisPlatt's Avatar
Not terribly limiting IMO. Simply use ISO 1600 speed film or slower.
The true film speed of 3200 rated films is below 1600, anyway.
Chris
09-01-2015, 05:40 PM   #6
If you happen to have a whole lot of 3200 film, I'm afraid you're stuck, as others have already said.
As for the aperture ring, if it's a Pentax-A lens it might be best to turn it to the A setting (if you still can) and leave it there. Yes, you will be stuck in program mode, but at least you can still use the lens. I would then go about finding another one on the Marketplace here.
If I'm right and the P3N is the same basic camera as my P30T, you don't actually lose much by getting K or M series lenses (or their non Pentax equivalents) rather than A - you lose full auto program mode, but you should still have aperture priority, which isn't much worse and may even be preferable for some.
In fact, they will function (meter and fire) with every Pentax lens right up to the DA series, though of course they will vignette with most DA zooms and some primes and also default to full program mode with any lens that doesn't have an aperture ring.
09-01-2015, 09:27 PM   #7
UncleVanya's Avatar
Based on what I read here https://en.m.wikipedia.org/wiki/DX_coding
ISO 1600 is represented by all but positions two and six bring conductive and 3200 is represented by all but position six being conductive.
So if you block with paint or very thin tape the second position on the 3200 ISO DX coded film you will get the camera to view that as ISO 1600. Either shoot as is one stop over exposed or remember to add a one stop adjustment to each shot.
Another more complex option would be to reload the film into 1600 coded canisters but I have no idea if that is easily done these days. Lastly you could make uncoded canisters look like DX 1600 coded by using aluminum duct tape and s hobby knife.
---------- Post added 09-02-15 at 12:37 AM ----------
Also check instructables. They have a guide to making DX coded labels.
Or this. Firstcall DX Recoder Labels, ISO 200
Wrong ones... These! http://www.firstcall-photographic.co.uk/products/750/firstcall-dx-recoder-labels-iso-1600
aperture, camera, dx, dx coding, film, iso, labels, lenses aperture, p3n, p3n / p30n, position, six, tape
A few questions about the Oben CT 2491 JHfwp Ask B&H Photo! 2 11-24-2014 07:45 AM
K-3 and FA lenses - aperture ring setting / focus ring zzeitg Pentax K-3 & K-3 II 10 11-05-2014 08:10 PM
Doubting about the Pentax K3, just a few questions Photographykn Pentax K-3 & K-3 II 35 10-02-2014 08:17 AM
A Few Final Questions About The K-3 Matthew Saville Pentax K-3 & K-3 II 15 02-24-2014 10:07 PM
just a few technical questions about how manual lenses work wehavenowaves! Pentax SLR Lens Discussion 11 03-23-2011 09:19 AM
All times are GMT -7. The time now is 02:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
