Originally posted by KungPOW You might also notice the focus at the bottom of the viewfinder is not the same as the focus at the top.
I recently acquired a LX.
Tested with Carl Zeiss 85/1.4 & 35/2.4. The results with the 35/2.4 looks pretty okay, but not with the 85/1.4 as I found the main subject is out of focus although it was in-focus from the view finder.
Contacted the seller and he advised I should perform the Diopter Correction. However I do not think it has anything to do with Diopter as it is for focusing convenience for eyeglass wearers.
From the instruction manual, somehow I do not understand what it means by turning the adjusting screw until the Border Lines of the center spot come in sharp & crisp. The FA-1 Viewfinder has a horizontal split with prism around it.
What is the "Border Lines"?
I mounted a M50/1.4 and focus about 6 feet from the subject. From the viewfinder, the center is on focus, but the top & bottom are out.
Turn the focus ring clockwise, the top is became clear, but the center is out as well as the bottom. I then turn the focus ring counterclockwise so that bottom is clear.
Appreciate someone can advice if the problem is due to the mirror or something else.
Thanks.
