That isn't a very good price for a relatively slow speed card according to its specs:
Write Speed 22 MB/s Maximum
Read Speed 30 MB/s Maximum
Your device may or may not be able to make use of the faster write speed, but if you use a ext. USB3 card reader, a faster read speed will be appreciated.
In my new videocam (a Panasonic HC-V750) I use a PNY Elite Performance 64GB card ("90MB/s"). I got this cheaply on Amazon and originally used it as a backup for a Sandisk 64GB ExtremePro in my Pentax K-3 (has two SD slots).
Amazon.com: PNY Elite Performance 64GB High Speed SDXC Class 10 UHS-1 Up to 90MB/sec Flash Card - P-SDX64U1H-GE: Computers & Accessories
The 64GB card is currently $28.99 USD. I'm in Australia and PNY shipped to me. (Many Amazon sellers won't.)
Using H2testw in an ext. USB3 card reader I measured the performance of this card :
Warning: Only 61086 of 61087 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 61.2 MByte/s
Reading speed: 82.5 MByte/s
H2testw v1.4
These measurements are in true MB (1,048,576 bytes). If using 1 MB = 1,000,000 bytes, as the HDD and memory storage industries do, these results would be expressed as:
Writing speed: 64.5 MByte/s
Reading speed: 86.5 MByte/s
The PNY has a lower write speed than the Sandlisk 64GB Extreme Pro which I measured in true MB (1,048,576 bytes):
Extreme Pro 64GB ("95MB/s"):
Writing speed: 81.3 MByte/s
Reading Speed: 83.8 MByte/s
In 1 MB = 1,000,000 bytes:
Writing speed: 85.2 MByte/s
Reading Speed: 87.9 MByte/s
The Extreme Pro's write speed performance is impressive. But it's unlikely that the HC-V750 can make use of the greater write speed here (it's not a 4K camera).
BTW, the methodology of accurately measuring the time taken by a SD card in the K-3 & K-5, and the results are described in these 3 msgs:
https://www.pentaxforums.com/forums/172-pentax-k-3/247218-k3-not-faster-than-...ml#post2641354 https://www.pentaxforums.com/forums/172-pentax-k-3/247218-k3-not-faster-than-...ml#post2652643 https://www.pentaxforums.com/forums/172-pentax-k-3/247218-k3-not-faster-than-...ml#post2658629
Dan.
