Originally Posted by AVANT
Slave mode 2 turns your flash into a standard optical flash. It won't work with the built in flash because it's P-TTL only. The preflash will set them off.
You can trick the camera flash to fire only once by finding a lens with an aperture ring and taking it off the A setting, but then your built in flash will shoot at full power and will also be included in the shot.
The only way to have off camera flash in Manual or A mode to my knowledge is to use a cord.
I know all that and that's how I use it with *istDS and M lenses, or DA lenses and power set ti 1/2 or less so AF360 can fire twice in rapid succession.
My question was what would happen if K10/20D flash is set to Wireless Control mode. That feature is missing in *isdDS so I can not test. K20D manual indicates that slave flash (mode 2) with on board flash in wireless mode is possible, but it is in the table and not clear enough.
My guess: it should work. Wireless control flash does not do a preflash. It initiates a protocol to trigger remote flashes to preflash so power can be adjusted. I am expecting AF360/540 in manual mode should be able to recognize "Pentax flash language" (which is not the same as a preflash) and NOT fire on that. But can not be sure.
