I've been experimenting with my own designs for bounce diffusers. My latest project is a simple catchlight bounce. Made of thin rubber-foam and satin-finish nylon, it's lightweight, extremely cheap and very, very simple to make by anyone with some glue and scissors. I'll post images of the set-up later, but for now I'll post images of my initial tests.
I'm ruminating on it's pros and cons, and any comments you'd care to add are most welcome...
INTERIOR SHOTS:
This is a pitch-black room at night - no lighting whatsoever besides my flash. I'm using a cheap non-dedicated bounce-flash on a flash-bracket fired by a Cactus-style trigger. Settings are fully manual.
Shot A) Note the reflection (top left of the glass sliding-door) of my hand holding the camera. You can see the wall behind me lit up by backflash. So that constitutes a portion of light wasted on the area behind the camera.
Shot B) The reflection in the glass now shows a white glare created by light from the catchlight-bounce. Note also that the wall behind me is no longer lit up. So that light has now been thrown forward, producing enough light to make the room brighter.
However, the catchlight bounce may be too effective, as it has eliminated the shadows from the ceiling-bounce (see area under kitchen bench), but has also created its own shadows (see edge of right-hand chair) that the ceiling bounce isn't strong enough to kill.
TEDDY BEAR:
As you can see, the shadows under the bear's head have been eliminated completely, which is probably overkill, as some shadow should be present to retain a sense of depth. I still like the image more than the straight ceiling-bounce which produces too strong a shadow.
CONCLUSION:
I think if shadow is to be created, then it should be the ceiling-bounce that does it, simply because our brains are geared to see under-shadow as being "natural" - as if sunlit - and back-shadow as being an anomaly specific to strobing. I want the natural look, so I might need to reduce the surface-area of my catchlight-bounce so that it's slightly overpowered by the ceiing-bounce but still has enough power to put that glint in my subject's eyes.
