...When there's no battery in there? I usually try to be sure and unplug my adapters when they aren't in use, cause of the waste of energy, but I wonder if it's necessary in this case.
If there is a transformer, it will draw power as long as it is plugged in. It may not be as much as when there is a battery, and it's charging, but there will be a draw.
Anything plugged in will draw power even if the unit is turned off it will draw power. COM ED sent out information with there bills stating this in how to save on your bill.
Right, that's at least the safe presumption. I understand it's sometimes possible to make things not do that. I usually keep the charger on a power strip that's generally shut off, anyway. Forgot yesterday, and was wondering if anything was really going on in there.
Electronic devices usually have a soft power switch, so there is always current flowing through it to allow you to power it on. Purely electrical devices like toasters or lamps, for example, will only draw power when it is activated.
In the case of wall wart transformers, the primary coil completes a circuit, and always draws a current when plugged in (unless there is a power switch).
I noticed this morning that the charger for my cordless drill was warm even though I pulled the battery out of it last night. It was promptly unplugged.
Nothing like a.... hard switch, eh?
It's a wonderful and high-tech device which enables the convenience of cutting power to something without moving the device around or crawling under cabinets to remove cords from the wall. Brilliant!
Just wondering if anyone happens to know.
Your TV, VCR, DVD, etc all draw power even when off. As for the Pentax charger it may use the battery itself to turn on the charger.
Pretty much anything that has a transformer like VCR, TV, wireless phone..etc.
They call them power vampires as they draw power without you knowing about it and they draw it slowly unlike if you have the devices set to "on".
