Originally Posted by Ash
Line of sight firing won't be mode-dependent but why you can't set your master/control flash to M mode is beyond me.
Perhaps try to set both up as wireless slaves in M mode with the onboard flash as master/slave.
I have been able to set both master and slave in M mode using a 540 and Sigma 500. Not sure why you're having trouble - but there are a number of possibilities not yet exhausted. Like try having wireless mode on camera set first, then sync the slave flash, then set the master up with flash not on wireless mode but rather the on mode (on the power switch).
I may have that mixed up (perhaps should be on the wireless mode on the power switch) but give it a try
Ash,
Are you talking about setting the wireless flash (I only have AF540 so no Sigma here to try) to SL2 mode and trigger it optically?
So far here is what I found:
For the attached AF540, I can only set it to Manual mode when:
1) Power switch = Wireless, set to Slave mode
2) Power switch = ON
For the wireless AF540 (detached from camera), I can only set it to Manual mode when:
1) SL2, Power switch = Wireless, Slave mode
and by using SL2 mode on wireless flash, I think it's actually optically triggered, not the real wireless.
Thanks,
