04-24-2011, 04:14 AM   #1
Pre-processing software/viewer
I am looking for something that I am not sure exists . I am looking for software that lets you view a wide variety of extensions (DNG, RAW), is streamlined, fast, and makes no changes to the images. Basically a photo viewer, that will allow you to tag and delete unwanted photos, without having to warm up the mothership of options.
Thanks
J
04-24-2011, 05:08 AM   #2
In a pinch I use the software that came with my camera the photo browser one to view images.
04-24-2011, 05:26 AM   #3
You could try FastStone, IrfanView or Picasa.
04-24-2011, 07:50 AM   #4
I wholeheartedly recommend XnView. I used IrfanView in the past, and I think XnView is much, much better. Take a look here:
Best Free Digital Image Viewer
The editor recently ranked Zoner Software 1st and XnView 2nd, but from his description I gathered that Zoner would not do batch conversions, so I preferred to stick to XnView. BTW, this site is very good at recommending free software for all kinds of purposes.
04-24-2011, 11:53 PM   #5
QuoteOriginally posted by causey Quote
Thanks a million......Exactly what I was looking for!!!! As quick as Picasa but you dont have to add the files to the program like Picasa to get something accomplished, nor does it try to change the file type
Thanks again!!
04-25-2011, 05:06 AM   #6
QuoteOriginally posted by treue_photo Quote
Thanks again!!
You're welcome. If you want to see pics on the entire screen, one after another, select the number of pics you want to see and click on "slide".
Also, for any kind of processing, I find it easier to use the "Batch Processing" in tools, whether I want to, say, quickly resize a pic or twenty pics. (I'm talking about XnView.)
04-25-2011, 01:22 PM   #7
Ya the software is cake!! I learned it and went through 500 pictures within a hour.
04-26-2011, 03:14 AM   #8
I'm a XnView (freeware) fan.
Irfanview's interface looks dated and doesn't get updated very often.
FastStone is popular and it comes down to taste.
I like the reconfigurability (you have preset, reconfigurable hot-keys for just about everything) and the very small size of XnView - easy to run from a USB stick.
You can also operate two independent sets of image selection: Tagged; Selected.
Tagging is when you click the little tick box at the top left of a thumbnail. You also have commands like "Show all (only) tagged files" and "Invert (tagged)".
Selection is the standard Windows file section methods like Ctrl-A, Shift & Ctrl selection modifiers as well as others like Invert Selection.
Say you had 4 files: 1, 2, 3, 4.
You tag 1 & 2.
You select 2, 3, 4.
When you right click and select Copy or Move (or use their hotkeys) you will be asked which set you want to use. (You can also tick a "Don't Ask Again" box). By the way, you can easily set up multiple Favourite directories for browsing & file operation destinations.
Tagging is cleared after an operation - Selection isn't. This can come in handy.
Good handling of file-already-exists situations. Both images are displayed with date, dimensions & file size shown. You can easily set up a rename.
Reconfiguration of panels and their size. Tabs used as well to save screen space.
Batch Processing (can be multi-process).
Batch Rename with drop-down templates, but you can easily amend or add your own.
Continuous frame shooting
Image Compare.
Contact Sheets.
Set up a Web Page (with thumbnails leading to bigger images (a number of different templates provided and others have contributed).
Freeware Photo Web Page Creators
Single or Multiple Screen Grabbing with Cropping.
Freeform & constrained cropped. Constrained by size or AR. Preconfigured ARs. You can also save your own from a current selection as a new "Custom" selection, and then bring it up again with the C hotkey. Handy when you're moving through a set of images and want to use the same crop frame. Switching of W & H with the Tab key i.e. from 640x480 to 480x640 or from 3:2 to 2:3.
Thumbnails: small to very large.
Open with... (Alt-1 to Alt-9 for your configured other raw converters and image editors, F3 for Associated Program, F4 for Associated Editor)
Image adjustment, filters etc.
Batch scripting via modifying, in a text file, options in command boxes.
Tip: XnView output directory relative addressing
You can also filter & sort in lots of ways. I like the different views of the the files when browsing and I've configured both the hover tool-tips & Details, as well as the overlayed Info panel in Image, Fullscreen and Slideshow views, to show EXIF info.
Some different ways to show EXIF exposure info in XnView
You can save different slideshows and and load them from your USB stick - great when you need to take some image to show to your workmates.
To speed up the loading of raw files, configure XnView to use the embedded JPEG preview rather than doing any on-the-fly DCRAW conversion: Tools | Options (or F12) | View | Misc | Camera Raw: Embedded Thumbnail.
The single EXE that does this is 4.3 MB so it loads fast and is easy to carry around. No other DLLs or or other files required. Config settings can be written to either the registry or to a local INI file.
Dan
04-28-2011, 08:12 AM   #9
Thanks for the tips Dosdan!!
Post Processing software? mariopato2010 Digital Processing, Software, and Printing 2 06-20-2010 04:54 PM
Photo Processing Software? NecroticSoldier Pentax Beginner's Corner Q&A 22 03-30-2010 10:18 AM
Processing Software - What do you use? pakuchn Digital Processing, Software, and Printing 61 03-23-2010 04:34 PM
Processing Software dragnb Pentax Beginner's Corner Q&A 5 10-14-2009 10:20 AM
Which processing software to use? vmax84 Pentax Beginner's Corner Q&A 29 09-08-2009 03:59 PM
