I use an internal card reader...it's cleaner plus I don't take up an external USB port and have to find the cable all the time.
Also don't have to find a secure place to set the camera while it's doing its thing. Personal preference, but it's something to think about. Speeds are probably close, with the edge to a reader.
__________________
K10D | D-BG2 | Vivitar 28/2.5 | Tamron SP Macro 90/2.5 + SP 2x Tele | Zenitar 16/2.8 | FA 80-320/slow | A 24-50/4 | Sears 55/1.4
Proud MF'er Manual Focus Forum Join us to fight "LBA" and post some pix. Together, let's get creative with what we've got.
I usually use the USB cable because I leave it connected to the computer and just plug the camera in. Taking the card out involves more effort and time as I have to open a door on the PC to insert it. Transfer speed wise doesn't really concern me as I usually walk away and do something else if there are heaps of files to transfer.
If I have only one days shooting on the card (which is usually the case) I use a little program called 'transferrer' that copies the files to a new folder created for todays date under a folder I've specified (eg 2008). What I would like is a program that copies the files to folders created based on the dates the files were taken, which is what our Ricoh digicam does. If I've got multiple days I manually copy the folders to where I want them and rename since the Pentax naming system is unsortable! If anyone has a program that does this in one step, please enlighten me!
Cheers, Nige
You have such a program already - it's in your camera. In the menus, find the option where the camera will create a separate folder on the card by date. It will start at 100-xxxx and the next day will be 101-xxxx and so forth. That's how I set up my K10D.
__________________
Albert in the Rockies http://www.flickr.com/photos/albert_berry/
SF-1, MZ-S, K10D + D-BG2 grip
M 100/4 Macro, M 400/5.6, A 70-210/4, FA 28-80, FA 24-90, DA 12-24/4, DA* 16-50/2.8, DA* 50-135/2.8, A 1.4X-S TC, AF 1.7X TC
Manfrotto 055B tripod + 0168 ball head, Benbo Trekker tripod, Velbon UP-43 Monopod
got that invoked already, however it ain't a proper date (it's the year 2008 here!) and has to be renamed (so it's half the solution). Who thought of that scheme (using "1nn" for a suffix)... What does it achieve? Why not use the real date?
I believe K20 does, I have that function disabled.
You could probably write something to do the autorenaming/moving in Perl quite easily.
