Go Back   PentaxForums.com > Pentax Photography > Everything Else
Everything Else Use this forum to talk about Pentax-related topics not covered in other sections, such as photo shoots, magazines, and rebates.
Old 08-06-2008, 09:40 PM   #1
can I use any of my old Nikon gear w/ my new pentax system?
I didn't see anything on the forums regarding this - I've got a nice Nikkor ED AF 80-300 2.8 zoom and a speedlight sb-22 but finding it hard to get info on adapters. Could I use the flash as a slave? it has an pc/xSync port which my k200d lacks, I'd love to get it working some way.
I understand mount adapters can result in the lens unable to focus to infinity, but I can't find if even a non-infinity-focusing adapter is available.
UPDATE - found this thread about nikon flashes with pentax, I guss I'll have to play around with it but sounds like it'll work! the lens is a much bigger deal though...
thanks for any info.
D
360fish is offline   Reply With Quote
Old 08-07-2008, 04:16 AM   #2
The Pentax and Nikon lens mount are almost identical, so I think with a little work, one could be made to work with the other.
flyer is offline   Reply With Quote
Old 08-07-2008, 04:38 AM   #3
When I switched from Nikon and Fuji to Canon I sold all my Nikon gear ... except my Nikon flash units. When I switched from Canon to Pentax I sold all my Canon gear ... but I still kept the Nikon flashes.
IMHO, Nikon simply does a FANTASTIC job with their flash units. The SB800s in particular are my favorite flashes.
I have several P-TTL flash units from Pentax, but I still use the Nikon speedlights as off-camera flash units ... and sometimes just as a fast-recycling Auto flash on camera.
Anyway, I wasn't a huge fan of Nikon DSLRs, but I'll never give up my Nikon flashes ... unless another manufacturer wakes up and makes even better flash units for roughly the same price (or less).
JJJPhoto is offline   Reply With Quote
Old 08-07-2008, 05:28 AM   #4
buy one of these and tell me if I should buy one (Will be manual focus and stop-down metering as no aperture or electrical contacts)
Nikon lens to Pentax K10d k20d k100d k200d DS adapter - eBay (item 350084478389 end time Aug-06-08 10:42:24 PDT)
HGMonaro is online now   Reply With Quote
Old 08-07-2008, 07:00 AM   #5
Wow, never knew that existed. But then again, this is only worth it for those of you already with Nikon gear. Nikon lenses (from what I've seen) are significantly more expensive than Pentax ones.
__________________
Pentax K10d | Tamron 18-250 | Tamron 90mm f2.8 Macro | Tamron 17-50mm f2.8 | Pentax 50mm f1.4
innershell is online now   Reply With Quote
Old 08-07-2008, 09:14 AM   #6
I've never heard of those adapters. I have a couple of Nikon paperweights they may work on but I don't know if I want to be the guinnea pig.
__________________
reeftool is offline   Reply With Quote
Old 08-07-2008, 10:57 AM   #7
The older (pre)AI lenses already fit in the Pentax bayonet and focus to infinity...
__________________
K10D | D-BG2 | Vivitar 28/2.5 | Tamron SP Macro 90/2.5 + SP 2x Tele | Zenitar 16/2.8 | FA 80-320/slow | A 24-50/4 | Sears 55/1.4
Proud MF'er Manual Focus Forum
Join us to fight "LBA" and post some pix. Together, let's get creative with what we've got.
ryan s is offline   Reply With Quote
Old 08-07-2008, 12:24 PM   #8
I have seen this item before but there is a optical element in it. I wonder how good the optics are for the price.
Nico is offline   Reply With Quote
Old 08-07-2008, 01:46 PM   #9
I can confirm this. I have an old pre-AI 300mm Nikon lens as well as a 105mm and a 28mm, all of which I have used on occasion.
I should take a few pics and add them to the "off brands" thread.
woof!
__________________
Seaain Gray
An rud a líonas an tsúil líonann sé an croí. ~ Irish Proverb.
("What fills the eye fills the heart.")
woof is online now   Reply With Quote
Old 08-07-2008, 04:36 PM   #10
I just tried to mount both Ais (105/2.5) and Pre-Ai (135/3.5) Nikkors to my K10D and they didn't fit. Bayonet fits the hole but won't turn more than a mm or so. Can take a picture but lens is close to falling off! Not recommended.
Old 08-07-2008, 06:14 PM   #11
woof!
Someone beat you to it. Quicksand posted some pics from his Micro-Nikkor 55/3.8.
__________________
Pentax K10D :: Pentax-M 200/4 :: Tamron 70-150/3.5 (Adaptall-2) :: LZOS MC Jupiter-9 85/2 :: Pentax-A 50/1.7 :: Pentax-M 50/1.7 :: Sigma 50/2.8 EX DG Macro :: Auto-Rikenon 50/1.7 (M42) :: Pentax-FA 35/2 :: Tamron 28/2.5 (Adaptall-2) :: Pentax-DA 18-55/3.5-5.6 :: KMZ MC Zenitar 16/2.8 :: Pentax Bellows-K
stevebrot is online now   Reply With Quote
Old 08-07-2008, 07:41 PM   #12
Big Dave's Avatar
Gallery Photos: 4
Hi,
The Nikon manual lenses fit the K-mount when properly positioned. You must make sure that the light baffle doesn't protrude more then 8.5mm into the body past the mount. Insert the lens with the index dot at about the 6 o'clock position. Seat gently. Take using the camera, since the lock pin isn't seated. Here is a photo of my 35/2 mounted on my K100DS.
Dave
Big Dave is offline   Reply With Quote
Old 08-08-2008, 03:26 AM   #13
thought I tried all positions... I'll give it another go!
Old 08-09-2008, 06:24 PM   #14
I just got a promaster 28-200 that the seller said was for pentax, it's actually nikon mount. The lens mounts just fine two ways. One way is to align the red dots almost perfectly, the other is to mount the lens upside down, aperture markings on bottom of the lens. Are both of these ways safe? Should I try to remove the pin/blade on the lens to prevent any damage or will that ruin the lens?
dave sz is offline   Reply With Quote
Old 08-10-2008, 11:21 AM   #15
nevermind, the upside down method or the 2 oclock method do not work. The lens goes in but there is no support, just falls out. Only way it stays is if I line up the dots almost perfectly and get a small turn in...
