When the K20D came out, I started the thread
Pentax really listens! Thanks!. The summary: in addition to the big improvements (expected and not expected), the K20D made a lot of small (some almost trivial) improvements to the K10D which addressed many forum complaints (both common and apparently rare). In that case, I highlighted the fine-edge-sharpening option, lower jpeg compression, and customizeable filename prefixes — and then others added on. The result is a quite-impressive list.
So, this time around, check out
this complaint) of mine, and now look at page 198 of the K-7 manual, which says:
You can copy the white balance setting of a captured image and save it as Manual White Balance.
Thanks, Pentax!
What else do you all have along these lines?
