It's almost always an improvement, if circumstances are appropriate, though the setup time can slow you down more than seems worth it. I like having my hiking-pole-with-gun/scope rest when walking around, and this idea has potential.
(Still need to get a less-bendy-springy pole to get real stability, something I've been putting off, but in concept this seems viable for quickness and convenience: at the moment the setup's really just best for helping me walk and compensating for any fatigue or weakness I might experience: primarily right now, it just helps me not fall down if I get really stiff in the joints, and may as well be camera support while it's at that job: just bracing the lens on that crook actually makes a good place to put your walking pole, if nothing else. )
But I use it with shorter lenses all the time, and in principle it should work well. Takes no time at all to put the camera on it, , and with the right qualities of actual stick, should give most of the benefit of a monopod. Steadiness is always helpful, if you can have it.
There's also a kind of neat Giottos monopod head with a quick release that looks pretty efficient and unobtrusive to me, (kind of has a round bit, comes with one of their monopods that has little legs you can add to it) which might be nice for such purposes.
...There's also a kind of neat Giottos monopod head with a quick release that looks pretty efficient and unobtrusive to me, (kind of has a round bit, comes with one of their monopods that has little legs you can add to it) which might be nice for such purposes...
You mean one like this? The head looks to be pretty much ideal for this application.
That looks like the thing. ( I've been sort of in a slow process of trying a few things on for concept with cheaper things before I make a big-for-me investment in something nice, but that kind of head has caught my attention. Looks about right: not bulky or squared-off, and you can turn the mounting itself rather than having another separate movement, if you want to go from flippy to tilty.)
The other concept is of course a ballhead, aforementioned y-rest, or no head at all. One thing I know about using such a thing for short lens work is, you'll want to take it off frequently.
You mean something like this attached to a monopod............
Same concept, only really all you need is basically the little piece of plastic with a rubber pad in it that comes with a lot of hiking poles. I think I've seen them available separately, actually. That Slik thing would probably be excessive for a shorter lens.
I think things with the head I'm talking about are most often sold as 'Shooting sticks' fairly often under outdoorsey categories in various places. The cheaper ones that come with such things seem to have perfectly good scope rests, so the cost isn't a big deal. I'm pretty sure I saw just the rests sold alone somewhere really cheap, and I'll be looking for a couple, myself.
(I just scored a little Gitzo knockoff monopod off Ebay: I've been wanting to try on the concept of carrying something really short on my belt or some such for a while, for just this purpose, and see if I really want to deal with unfolding all those sections before investing in something nice. So, I'll maybe report on how that goes. Let me see if I can find those things. )
Here's a random listing for the kind of pole combo I'm always taking about. This one's apparently a real cheapie:
I've been thinking of making a stealth (or at least multipurpose) cane/monpod based on an extensible cane with a Derby head.
I've had very good luck using a Y shaped yoke atop a shooting stick, which is pretty obvious and isn't as easy to tote around as a Derby Cane would be. A stealth monopod might be useful in museums, at the theater, etc.
Walmart's got a nice, lightweight, camera black (Remington?) Shooting Stick for $9.97.
Iowa Dave
PS that's what I'd put a Derby Cane head on most likely.
I've have very good luck using a Y shaped yoke atop a shooting stick, which is pretty obvious and isn't as easy to tote around as a Derb Cane would be. It might be useful in museums, at the theater, etc.
Someone mentioned that on another thread. (Actually, I think it was one I started myself a while ago, looking for recommendations on a better version of my hiking pole itself. ) The cane head could be a good concept for me, since there are times when one knee or hip or the other could stand to have the load taken off.
