An older idea is just to use a loop of string, the right sort of length to loop over the lens and brace with your feet, making a triangle. It allows you to adjust somewhat for angle.
Not something I really troubled with, but it can work.
If you use it be very certain that the camera strap is securely around your neck.
There is a strong and potentially disasterous downward pull on your camera.
