Originally Posted by raider
That's a very good point. Can you recommend other tripods which can carry the load I intended but are just as light as the slik and won't cost an arm or a leg? This tripod will be used by my wife and so i am trying to get one which is as compact as possible.
I can recommend the Velbon Sherpa Pro carbon fibre tripods. Yes, they are more expensive, but if you do a little search, you'll find them at very competitive prices. I have a small Sherpa Pro 540, which weighs about the same as the Slik, you contemplated. I added a Novoflex Ball 30, because it has about the same load capacity as the Sherpa Pro (app. 4 - 5kg) and is very lightweight itself (225g) - so its an excellent match. This combination will easily carry your envisaged equipment and leaves enough room for bigger and heavier equipment too, but is light and small enough to carry it around all day.
Ben
