Go Back   PentaxForums.com > Pentax Photography > General Pentax Photography
General Pentax Photography Discuss the fundamentals of photography, Pentax camera modes, infrared and macro shooting, and related topics here!
Old 07-21-2008, 12:39 AM   #16
RioRico's Avatar
Location: central Sierra Nevada mountains, California, USA, planet Terra
On the K20D, does setting the Capture Processing function to Monochrome-Infrared actually produce an IR image (ie, is the hotmirror whisked away), or is it just a simulation???
Yes, Fuji has a small line of forensic DSLRs, with varying IR/UV capabilities. Sigma also has an IR-friendly DSLR, notable in that the IR/UV blockers are in FRONT of the reflex mirror, and are easily removed and replaced, so the user can narrow-in on any desired portion of the 'light' spectrum.
To try IR without spending in the Fuji-Sigma cost range, and/or without having your DSLR permanantly blinded to visible light, look to eBay. Many PNS cams more-or-less modified for IR are available for $200-$400. Or you can buy an old Sony DSC-V1 with NightShot which snaps-away the IR hotmirror, then get an adaptor tube and an R72 or whatever IR filter. With both the Sony V1 and Minolta Dimage F300-IR, I can shoot handheld in daylight at up to 1/250 sec. No more stinking tripod!
A note on IR conversions: If you have your DSLR's hotmirror removed (which will cost you a couple hundred bucks), it's not permanently blinded to visible light. You can always buy an expensive IR-blocking filter to give you living color again. Let's see, that filter also costs a couple hundred bucks... Hmmm...
__________________
Pentax: DA 10-17,18-55,18-250; FA 100-300,50/1.4; ST 40-80M,70-200,135,55,35,28
Other PK: Sig 35-80; Viv 24/2, 90M; Toyo 28; Focal 135; Sakar 500/8 mirror; more
Screwmounts: Vemar 12; Sig 24; Viv 28; Isco 35; Mir-1; Helios-44; Jupiter-9,11;
Meyer 35,50,100,180; Enna 35,100,135,240; Alpa 300; Rubinar 1000/10 mirror; more
RioRico is offline   Reply With Quote
