Go Back   PentaxForums.com > Pentax Photography > General Pentax Photography
General Pentax Photography Discuss the fundamentals of photography, Pentax camera modes, infrared and macro shooting, and related topics here!
Old 08-27-2008, 02:51 PM   #1
Question 1/2 or 1/3 EV stops?
I've searched over the Forums but I couldn't find much information regarding this topic.
My question is, is there any advantage of either setting in the custom menu, to set exposure with 1/2 or 1/3 EV steps? Is 1/3 more accurate, but 1/2 faster to dial in? Or are both just as accurate and it's just there because someone would find either setting prettier?
Nanthiel is offline   Reply With Quote
Old 08-27-2008, 02:53 PM   #2
ftpaddict's Avatar
Gallery Photos: 6
Thought I've used 1/2 ever since I got the K100D, but have recently switched to 1/3, to be able to make more subtle adjustments to exposure compensation.
You should have added a poll with this.
__________________
My Blog < See this? CLICK IT!
My Website < THIS ONE TOO!
Themes of Time
ftpaddict is offline   Reply With Quote
Old 08-27-2008, 03:00 PM   #3
BBear's Avatar
Gallery Photos: 13
I guess you said it all: one is faster and the other has more adjustibility.
I am on the lazy side (as of today) and I use 1/2 increments... Actually it is more than laziness. i actually got used to the fractions and I have the impression 1/3s would somehow confuse me a bit.
__________________
FA 35mm f/2 | A 50mm f/1.4 | FA 77mm f/1.8 Limited | DA* 50/135mm f/2.8 | DA 55/300mm | DA 16/45mm f/4 |
FOR SALE: ~ A 50mm f/2.0 ~ Vivitar 28mm f/2.8 MC Wide Angle ~ Vivitar P/KA 70-210mm f/4.5 Macro
BBear is offline   Reply With Quote
Old 08-27-2008, 03:04 PM   #4
ftpaddict's Avatar
Gallery Photos: 6
In practice I have found that keeping the EV comp. button pressed and rolling the dial a couple of times with either of the settings gets me to one end of the scale or another.
One extra click of the dial would take you probably .3 of a second to do, so speed should not be a major factor.
__________________
Themes of Time
Old 08-27-2008, 03:09 PM   #5
Bah! Totally forgot I could've added a Poll... it's not doable now, is it?...
I also noticed that you can push EV comp to -/+3 if you're at 1/2 steps, and to only -/+2 if you're using 1/3... although I usually wouldn't need to compensate -that- much.
But what about Sensitivity Steps? Do you set them per 1EV or as the EV setting?
Old 08-27-2008, 03:09 PM   #6
I use 1/3 - I have +0.7 EV pretty much permanently dialled in, seems to be around the normal "programmed in" underexposure.
simon
__________________
Landscapes & Seascapes of North Wales, including the Isle of Anglesey and Snowdonia National Park
http://www.landscapephotographyuk.com
simonkit is offline   Reply With Quote
Old 08-27-2008, 03:23 PM   #7
mithrandir's Avatar
I have done the same as Simon. My K10D is set at +0.7 EV to compensate for programmed underexposure; therefore I am using 1/3.
__________________
All we have to decide is what to do with the time that is given us.
mithrandir is offline   Reply With Quote
Old 08-27-2008, 04:03 PM   #8
Yeah, that's about the only advantage to 1/2 steps is if you want THAT much EV comp.
I keep mine in 1/3 steps as my primary adjustments for my lenses are +.3 for my DA zooms and +.7 for my FA primes... that's just kind of how it works out most of the time for my usage. I like the ability to dial in smaller more accurate steps now. But when I first got my Pentax, I used 1/2 until I became familiar with the metering and specific lenses.
As for EV comp, if I'm in a strange or tough situation that requires more than my normal subtle amounts, I realize it's time for Manual Exposure as it's easier to whirl the thumbwheel and dial in differing exposures than to keep setting and resetting the EV comp and checking and readjusting then shooting....
I keep the sensitivity steps the same as EV, because as for me, simple math to adjust ISO and EV in the same number of steps either which way....
augustmoon is offline   Reply With Quote
Old 08-27-2008, 04:05 PM   #9
sewebster's Avatar
I _almost_ wish you could just set it to full stops as even half stops seems like overkill on adjustability most of the time. Though I guess for exposure compensation it would be more important than just setting aperture and/or shutter speed in Av/Tv or M modes.
sewebster is offline   Reply With Quote
Old 08-27-2008, 04:40 PM   #10
timbo13's Avatar
Gallery Photos: 4
I keep mine at 1/2 steps because my manual lens are set by 1/2 steps, I would get confused shooting A lenses one way and M lenses the other.
__________________
Tim
Pentax K100D super & a collection of old and/or low cost lenses
more of my photos
timbo13 is offline   Reply With Quote
Old 08-27-2008, 04:46 PM   #11
kerrowdown's Avatar
I use 1/3 's all the time for just that little extra control on what I'm doing
It's really each to their own, there's no right or wrong here, just whatever suits your style and workflow.
__________________
A 30 year Pentax man, took the leap of faith to digital, but still using fast manual glass.
Darkroom no more, CS3 in the light.
kerrowdown is offline   Reply With Quote
Old 08-27-2008, 05:26 PM   #12
philmorley's Avatar
I use 1/3 and have +.3 or +.7 dialed in, depending on the lens
philmorley is offline   Reply With Quote
Old 08-27-2008, 08:04 PM   #13
Lowell Goudge's Avatar
I change as a function of lens type.
KA mount and newer, i.e. lenses with an "A" setting, I use 1/3 stops.
for K mount, non "A" lenses I use 1/2 stop because that is how the lens is indexed. I have found from time to time, some very inconsistent behavior when I use lenses that have 1/2 stop detents, with 1/2 stop AE in the camera
Lowell Goudge is online now   Reply With Quote
Old 08-28-2008, 12:54 AM   #14
Marc Sabatella's Avatar
Gallery Photos: 10
Same here. Also, I learned the sequence of f-stops and shutter speeds in 1/2 EV steps based on film lenses. I have no interest in having to relearn the sequences in 1/3 EV steps.
Marc Sabatella is offline   Reply With Quote
Old 08-28-2008, 03:17 AM   #15
creampuff's Avatar
Gallery Photos: 30
I use 1/3 EV increments simply because when shooting quickly falling light like landscapes and seascapes, there is a big difference when bracketing compared to 1/2 EV. Old habit but I've always preferred 1/3 stop increments since the days of shooting slide film.
1/3 EV is also useful when doing exposure in controlled studio situations for product shots.
When shooting in SV mode or TAv mode or when selecting ISO manually, it is also good to have a slightly wider ISO increment range, hence 1/3 EV.
The only negative is that EV compensation range is from -2 to +2. It should have EV adjustments to +/- 3 imo.
creampuff is online now   Reply With Quote
