I am just starting to experiment with off-camera flash and am putting together a small collection of equipment. I have two manual flashes with lightstands and radio triggers and would like to get an umbrella or two for times when there is no wall or ceiling handy. I would like to get a shoot-through umbrella because I like what the strobist site has to say about them. I would also like to get one bounce umbrella also. I don't know whether I will get more use out of a white or silver bounce umbrella. My question is directed toward those that have used both. If you were to buy a bounce umbrella for a small starter kit, would you buy white or silver?
All input is appreciated. Thanks, folks.
__________________
Pentax K10D, DA 18-55, FA 35mm F2.0, M 50mm F1.7, SMC Tak 50mm F1.4
Tamron Di 90mm F2.8
Sigma UC-II 70-210 F 4-5.6
Vivitar 28mm F2.8
Sunpak 383 Super, 433D
I've got 2 shoot-thrus and 1 reflector. I'm slowly trodding through Lighting102 and so far I've only used the reflector once though I wouldn't go so far as to say either is better - they merely have different uses and most of what I've done I wanted a softer light. If you are trying to limit "things" you might want to try a Westcott convertible: Westcott 43" Collapsible Umbrella with Removable Cover 15" FOLDED
__________________
- Jim
Resident Pain in the Aperture My Gear
there's differences between brands as well... I've got both a Wescott 43" and JTL 40" silver umbrellas, but the Wescott has a much more matte finish than the JTL umbrella. So the JTL has a much shinier finish, and casts a bit harsher light than the Wescott.
From what I've read, the silver generally reflects a bit more light than the white does.
__________________
__________________________________________________ _
Dan M.
That would be the best day ever in my book... www.pentaxphotogallery.com/danielmorgan
Reason: corrected my grammer - sorry i've had little sleep
I don't know what your manual flashes are like power wise, but when using a shoot through umbrella, I have found "regular' flashes to be inadequate. Keep in mind that you may need to up the ante there. If I had to pick between on or the other, I'd go shoot through, but with marginal flash bank, the reflective one may be the better option. That's just from my experience in the late '80s.
Edit: One thing you can do to help with harshness of a reflective umbrella is use colored diffusers on your flash head.
__________________
K20D, K200D, DA 35mm Macro LTD, FA 50mm f1.4, DA 55-300mm, Sigma 105mm, Sigma 20-40mm f2.8, F 35-70mm
