Go Back   PentaxForums.com > Pentax Photography > General Pentax Photography
General Pentax Photography Discuss the fundamentals of photography, Pentax camera modes, infrared and macro shooting, and related topics here!
Old 09-21-2008, 04:15 AM   #1
testing the water
ok having had my new k200d for a few weeks i tried doing some slow shutter effects... the first one was in full manual, using a 18-80 mm tokina lens, polarizing filter, shutter speed was about a second. I know there's some area's blown ( washed) out but if i had a faster shutter speed i prolly wouldn't have got the desired water effect. the question is... did i do right or did i screw it up completely?
the 2nd one.. well it's the same picture... i just went completely nuts in adobe lightroom and came out with this..lol
thanks
shed301 is offline   Reply With Quote
Old 09-21-2008, 04:20 AM   #2
Mike Cash's Avatar
Gallery Photos: 6
Why did you shoot at ISO1600?
If you want to get your shutter speeds longer, drop the ISO as low as it will go.
__________________
If Jesus had a camera he would use Takumars.
Aminus3 One-A-Day Photoblog /// My Geotagged Photos
Mike Cash is offline   Reply With Quote
Old 09-21-2008, 05:00 AM   #3
Taff's Avatar
These havent turned out the best
lowest iso, and use a tripod for sturdyness, keeping shutter speed as low as possible!!!
You actually dont need such a long shutter as one would imagine to get the soft water effect
__________________
MY FLICKER
K20D, Sigma 70-200 2.8, Sigma 28-90 macro, Sigma 18-50, Sigma 55-200, Pentax m 50mm 2.0, Osawa 28mm 2.8, Bower 80-200 4.5
Taff is offline   Reply With Quote
Old 09-21-2008, 07:48 AM   #4
kerrowdown's Avatar
You may also need to use ND filters to get slow enough shutter speeds
__________________
A 30 year Pentax man, took the leap of faith to digital, but still using fast manual glass.
Darkroom no more, CS3 in the light.
kerrowdown is offline   Reply With Quote
Old 09-21-2008, 08:55 AM   #5
mithrandir's Avatar
I don't know if the K200D has the same capabilities as the K10D, but with the K10D you can take a multiple exposure (9 shots) which can give great water effects without too much worry with ND filters and exposure settings. You might want to try this (with a tripod of course) if the K200D supports multiple exposures.
__________________
All we have to decide is what to do with the time that is given us.
mithrandir is offline   Reply With Quote
Old 09-21-2008, 12:10 PM   #6
Mike and Taff
i did shoot it at 1600 actually and i did it because i thought the lower you go in shutter speed, the higher you go in ISO. Obvousily i was wrong
Taff you think i could get away with maybe a higher shutterspeed like around the 4 sec and maybe ISO 400?. i was using a polerising filter and it was a overcast day and it was setup on a tripod, infared remote control etc
I'll have another crack at it today with your guys advice and see what happens
much appreciated and will let you know how it turns out
cheers
Grant
Old 09-21-2008, 02:44 PM   #7
Mike Cash's Avatar
Gallery Photos: 6
If you're getting a 1 second exposure at ISO1600 (nevermind that it was overexposed for the moment), then this is what would happen with changing the ISO:
800 = 2 seconds
400 = 4 seconds
200 = 8 seconds
100 = 16 seconds
__________________
Old 09-21-2008, 03:48 PM   #8
JonPB's Avatar
Gallery Photos: 15
There are three elements to exposure: shutter speed, lens aperture, and capture sensitivity. These three add up to how bright the image is. Longer shutter speeds let in more light, making for a brighter image. Wider apertures (represented by lower f/ numbers) let in more light, too. Higher ISOs increase the amount of brightness for a given amount of light. So, if you want to lengthen the shutter speed (presenting the sensor with more light) while not affecting the overall exposure level, you need to stop-down the aperture (to a higher f/ number) (this decreases how much light can flow through the lens) and/or decrease the ISO (decreasing how much the sensor responds to light).
Another way to look at it is that the following three things will make the image brighter: longer shutter speed, wider (lower) aperture, higher ISO. The following three things will make the image darker: faster shutter speed, smaller (higher-numbered) aperture, lower ISO. So if you lengthen the shutter speed, the image will be brighter unless you compensate by darkening the image with a smaller aperture or lower ISO.
Don't worry--this stuff isn't intuitive. But learning it will help you use your camera better. Cheers!
Last edited by JonPB; 09-21-2008 at 03:51 PM.. Reason: Had something backwards. Erp.
JonPB is offline   Reply With Quote
Old 09-21-2008, 05:20 PM   #9
You may also want to explore the "Sv" (sensitivity) mode, where you select the ISO and the Pentax will sort out the speed and aperture.
__________________
Make a little one happy this Christmas
Clicker is offline   Reply With Quote
Old 09-27-2008, 04:32 PM   #10
ok went out for *take two* and with a smile on my face these are the results
and this one
much better and more pleasing result
thanks to all that offered assistance with my problem. greatly appreciated, Now just got to wait for the *understanding exposure* book to arrive into new zealand
Old 09-27-2008, 06:24 PM   #11
looks like a great learning experiance!!! keep the pictures coming
__________________
Tyler. PENTAX K100D, Cosina K-28mm f2.8, FA 50mm f1.4, Magnum k-135mm f2.8, 18-55mm, 50-200mm, manfrotto tripod, A couple of accessories
Tb Photos Flickr Stream
Tb Photos
Tb Photos blog
ghost is offline   Reply With Quote
Old 09-27-2008, 08:27 PM   #12
Taff's Avatar
muchbetter mate, these look gr8
__________________
MY FLICKER
Old 09-27-2008, 09:19 PM   #13
shed301: I hope you don't mind me tweaking one of your shots a little. I think it was too blue and maybe I went overboard, but here goes.
__________________
A bunch of glass, constantly changing and evolving.
http://storpotaten.blogspot.com
pingflood is online now   Reply With Quote
Old 09-27-2008, 11:21 PM   #14
wow your right ping. it did look blue.... maybe have the WB off a little . what program did you use to correct it coz it looks bloody awesome
Old 09-28-2008, 05:44 AM   #15
nupentaxian's Avatar
Ping i think u went a lil overboard...water looks purplish...
__________________
Website
nupentaxian is offline   Reply With Quote
