Go Back   PentaxForums.com > Pentax Photography > General Pentax Photography
General Pentax Photography Discuss the fundamentals of photography, Pentax camera modes, infrared and macro shooting, and related topics here!
Old 10-11-2008, 09:48 PM   #1
heliphoto's Avatar
Quick-Shift focusing for lenses that lack it.
Yesterday, I stumbled on a suggestion somewhere over on DPR to use the lens release button to simulate quick shift focusing for lenses which lack this feature. The idea is that since the focusing gear (proper term?) is retracted while the lens release button is depressed, you can manually focus the lens, and when you let the button out, you're back in AF mode... I played with this today with my tamron 90 macro, and it works nicely. I thought I'd post here to spread the knowledge as it's an interesting trick and I'd never heard of it till now.
I don't think this is the thread I read yesterday, but here's a similar post.
__________________
josh
/ my blog / my photos /
heliphoto is online now   Reply With Quote
Old 10-12-2008, 06:11 AM   #2
marlon's Avatar
Sounds like a plan, but not one im comfortable doing, just like I don't like using spanners as hammers.
Maybe someone else could advise on the wear/tear and feasibility of this?
__________________
Pentax K20d
Sigma DC EX 18-50 f2.8, Sigma DG 70-300 APO, Pentax F 28-80, Cosina 28mm f2.8, Pentax 18-55 DA II, Raynox DCR 250
Marlon Brandon v/d Linde http://photos.mbvdl.net
marlon is offline   Reply With Quote
Old 10-12-2008, 06:14 AM   #3
JCSullivan's Avatar
Thanks Josh, neat trick. But what is a Quick-shift??
__________________
This is my sigfile and not part of the thread:
An avid supporter of Italian football/soccer/calcio (Forza Azzurri and Juventus)
If you have bird images you might want to upload go to www.birdsite.org. NO ADVERTISING
Identify insect at http://bugguide.net/node/view/15740
JCSullivan is offline   Reply With Quote
Old 10-12-2008, 06:26 AM   #4
jmc7104's Avatar
Gallery Photos: 7
Cannot see what difference it would make as far as mechanical wear is conserned. The feaasibility would have to be determined by the user, hiwever I wouldn't want to unlock a heavy lens like a 200 f2.8 or 500 ect. jim
jmc7104 is online now   Reply With Quote
Old 10-12-2008, 06:36 AM   #5
Spongefingers's Avatar
This could be an interesting technique for some people, but I'm not convinced it's really worth doing unless you feel you absolutely have to quick-shift.
The focus driver is retracted when you press the lens release button - so it will almost always be misaligned with the lens focus drive socket after twisting the focus ring manually and releasing the button. So when autofocus is next activated, there will be that unpleasant click and delay.
Also, as the lens mount locking pin is also retracted when the button is pressed, there may be a risk of the lens twisting on the mount when handled (admittedly a remote one.??)
Staying in manual-focus could be just as quick in most circumstances.
Spongefingers is offline   Reply With Quote
Old 10-12-2008, 08:48 AM   #6
heliphoto's Avatar
Quick shift is the automatic de-clutching mechanism on most of the new Pentax DA lenses which allows the user to manually turn the focus ring after the camera has auto-focused.
__________________
josh
Old 10-12-2008, 09:46 AM   #7
heliphoto's Avatar
Well I don't like it but I've used many objects as hammers, spanners included. I don't think I'll do this often, but it surprised me that I'd never heard of it.
I was just thinking that it would be fairly unworkable with my bigma.
I can see using it once in a while... for instance to fine tune focus on the eyes in a portrait. It's true that leaving the camera in MF would be better if you were doing a series of portraits, or had time, but if you just wanted a quick one off adjustment, and wanted to remain in AF for quicker response in dynamic conditions this might be work well.
With most of my lenses, I can't imagine the lens disengaging from the mount while doing this, as the fit is quite tight.
__________________
josh
Old 10-12-2008, 12:36 PM   #8
Marc Sabatella's Avatar
Gallery Photos: 10
I remember when that suggestion was made previously. And my reaction then was the same as it is now - how is that an improvement over simply flipping the AF/MF switch? when you want to focus manually? Mind you, I think both are a drag, which is why I pretty much will not buy an AF lens without quick shift.
Marc Sabatella is offline   Reply With Quote
Old 10-12-2008, 05:17 PM   #9
deejjjaaaa's Avatar
K20D has such a flimsy AF/MF switch, I am afraid to touch it... plus lens release button will allow you to use trap focus/catch in focus (see my answer to hinman there Questions on Sigma 105mm f/2.8 1:1 Macro Ex (non-DG))
__________________
deejjjaaaa is offline   Reply With Quote
Old 10-12-2008, 06:20 PM   #10
mithrandir's Avatar
Don't forget to double clutch.
__________________
All we have to decide is what to do with the time that is given us.
mithrandir is offline   Reply With Quote
Old 10-12-2008, 10:14 PM   #11
Canada_Rockies's Avatar
Gallery Photos: 25
With my middle name, "Klutz", I always try to have the camera and lens above a softly cushioned surface before I press the lens release. I can just see me doing this trick with a lens and seeing pretty pieces of broken glass winking at me before I finish.
__________________
Albert in the Rockies http://www.flickr.com/photos/albert_berry/
SF-1, MZ-S, K10D + D-BG2 grip
M 100/4 Macro, M 400/5.6, A 70-210/4, FA 28-80, FA 24-90, DA 12-24/4, DA* 16-50/2.8, DA* 50-135/2.8, A 1.4X-S TC, AF 1.7X TC
Manfrotto 055B tripod + 0168 ball head, Benbo Trekker tripod, Velbon UP-43 Monopod
Canada_Rockies is offline   Reply With Quote
Old 10-12-2008, 10:39 PM   #12
deejjjaaaa's Avatar
you just rotate the focusing ring w/ the same hand that keeps the button pressed, as your palm is under the lens and your fingers are keeping it over the focusing ring nothing will happen... unless your fingers are real weak.
__________________
Old 10-12-2008, 10:40 PM   #13
Gallery Photos: 25
Mine aren't weak. Just clumsy.
__________________
Old 10-12-2008, 11:34 PM   #14
LaRee's Avatar
Gallery Photos: 16
Yeah me too. I have enough of a challenge using a tripod without doing something clumsy. To each their own, but I don't push on that button unless I am changing a lens.
LaRee is offline   Reply With Quote
Old 10-13-2008, 04:15 AM   #15
JCSullivan's Avatar
Ahaaaaaaaaaaaaa!!!! Now I know why my newest addition, the 10-17 DA acts in this manner. I thought it strange at first but now it makes sense.
Thanks.
__________________
