right now i'm away, under a beautiful stary sky and have forgot my remote control. Attempting to get a star trail shot. I can try hold the shutter down for a few minutes in bulb mode but is there a better way. is there a way of setting a max exposure time that is longer than 30sec in manual mode?
You can get a wired remote with a "lock" button, or you can do it CHEAP: Get a mono 2.5mm jack plug and plug it in where you'd normally plug the wired remote. This will make the camera half-press the shutter. Once you press the shutter release, the shutter will fire and stay open. Remove the jack plug to release the shutter.
[quote=kskjon;65475]... Get a mono 2.5mm jack plug and plug it in where you'd normally plug the wired remote. ... QUOTE]
Wow, that was clever. When I saw "mono" I thought it was a mistake, but you fool the camera into keeping the shutter open then "pull the plug" to end the exposure.
I had a mono plug lying around, and thought of experimenting it to see if I could make a cheap remote, and discovered that it would hold the shutter by itself. So now I always keep a small jack plug in my bag.
Alright below is the shot that i got. Exposure was 405sec at 1.7. I used a Pentax SMC - A 50mm - great lens. I had to sit on a chair and hold the shutter release down for the entire time - the squiggle you see are the stars in line with my pulse - i was like a statue - well at leat i though so. BTW it was approx 0 deg celcius whilst taking the shot.
I would have loved to have the remote or something, perfect star lines would have made a great shot. This was my first ever attempt at Astro photography and using the bulb mode on my K10D.
Did you have any luck figuring out the cheap remote? If so, care to share the wireing diagram?
I made a switch last night for my k100d to work for longer exposures in bulb mode. Seems to work great. Here is a link to the instructions, and a wiring diagram.
