Go Back   PentaxForums.com > Pentax Photography > General Pentax Photography
General Pentax Photography Discuss the fundamentals of photography, Pentax camera modes, infrared and macro shooting, and related topics here!
Old 06-20-2007, 12:48 PM   #1
Polarized Filter Who Use Them?
So, soon I'll be going on my first cruise to Jamaica and Grand Caymans... Now... I think I'll be taking my 16-45mm and tamron 70-300mm di.
I know I'll be taking a lot scenic pictures and I want to make sure I get some decent sky pictures..etc. Should I invest in a polar filter? How many people use these today? I know on my old camera I have one but with my this k100d, I have 4-5 different lens with various size filter ring so I think I'll just buy it for the 16-45mm..
__________________
//K100D //Pentax 16-45 //Tamron 70-300mm DI //Pentax-A 50mm f1.7 // Pentax 50-135 DA*
http://www.zooomr.com/photos/johnyeros
johnyeros is offline   Reply With Quote
Old 06-20-2007, 12:58 PM   #2
I've got a B+W Thin MRC 67mm polarizer for my 16-45. It did cost quite a bit for a polarizer but I was not going to compromise on its quality. So far, I did not use it alot (I only owned it for a week now). Tomorrow, I'll be going out to shoot some cityscapes and I do plan to use it alot. I'll report back after
__________________
Body: Pentax K10D
Lenses: Pentax DA16-45 F4 | M135 F3.5 | M50 F2 | Vivitar Series 1 70-210 F3.5 (Kiron) | Revuenon 55 F1.2
Flashes: Pentax AF360FGZ | Nikon SB-24 & SB-25
My Photography Blog
barendvl is offline   Reply With Quote
Old 06-20-2007, 01:04 PM   #3
Peter Zack's Avatar
Gallery Photos: 61
A polarizer is still one of the most used filters with a digital. Many of the other effects used in the film era with a filter can be duplicated in PP but not what a polarizer does. IMO Before you buy one consider getting one that fits your largest lens, then get stepping rings that will adapt the filter to fit some or all of your other lenses assuming the sizes aren't too dramaically different. If you have for example a lens that is 77mm and the rest are between 58 to 49mm then get a 58mm with rings and then a seperate one for the 77mm. You'd need too many stepping rings for that wide a size variation.
__________________
http://photographyandhowto.blogspot.com/
http://peiweddingphotography.googlepages.com/home
http://www.themesoftime.com/Gallery.aspx
Look and think before opening the shutter. The heart and mind are the true lens of the camera.
- Yousuf Karsh
Peter Zack is offline   Reply With Quote
Old 06-20-2007, 01:47 PM   #4
I think a polarizer is a must have accessory. Unlike a lot of other filter effects, you really can't mimic the polarizing effect using software. Peter’s suggestion of getting one polarizer and stepping rings is a good idea. Another way to go is to invest in a Cokin polarizer and filter holder with adaptor rings for each lens. I use the same Cokin P series polarizer on all my lens which would otherwise require 4 different filter sizes.
__________________
Chris S
Photographic Diversions
http://photodiversions.blogspot.com/
Chris S is offline   Reply With Quote
Old 06-20-2007, 01:55 PM   #5
Gallery Photos: 5
It is one of two filters I own and carry about when taking photographs. However, I have to admit that most of the time I just plumb forget to use the filter - bad habit or just overwhelmed with all the other aspects of the shots to remember the filter . Anyway, when I do remember it does make a difference. Purchase the best you can afford.
squarerigger is offline   Reply With Quote
Old 06-20-2007, 01:58 PM   #6
Mark Castleman's Avatar
Gallery Photos: 11
A polarizer (be sure to get a circular polarizer) is one of the handiest things you can take with you and, as was mentioned previously, is something that cannot be simulated (at least not easily) on the computer. I have also used the Cokin system for years and I always have my polarizer, a set of ND filters and some graduated ND filters with me all the time.
Mark Castleman is offline   Reply With Quote
Old 06-20-2007, 02:10 PM   #7
Peter Zack's Avatar
Gallery Photos: 61
I totally agree with the Cokin system and have 2 holders with polarizers and ND's etc. It is a great versatile setup which gets the most use. The only thing is for travel I find it a little cumbersome to cart around. The stepping rings and one filter (or 2 if you need an ND) are a little smaller and fewer parts in a travel bag. The other advantage is price. Cokin is very good stuff and it shows in the price. You'll need stepping rings from them as well with different lens sizes.
Either way you can't go wrong.
__________________
- Yousuf Karsh
Old 06-20-2007, 03:27 PM   #8
khardur's Avatar
Gallery Photos: 11
I'd recommend (graduated) ND filters more importantly for skies. I use my polarizer often, but more around water, or to reduce reflections/pump up color of foliage or other subjects, but I found myself using the ND filters more often when it concerns skies.
Don't get me wrong, sometimes polarizers make the sky look wonderful, sometimes it makes it look - well - odd - fake, or something not necessarily desirable. (in my opinion).
Either one isn't the perfect solution for every situation. And I agree too, buy the biggest size you can and get step-up rings to fit smaller diameter lenses, or get a Cokin set.
__________________
__________________________________________________ _
Dan M.
That would be the best day ever in my book...
www.pentaxphotogallery.com/danielmorgan
Last edited by khardur; 06-20-2007 at 05:42 PM.. Reason: clarification - talking about graduated ND filters
khardur is offline   Reply With Quote
Old 06-20-2007, 04:08 PM   #9
Ah yes, the old "circular vs linear" debate.
Received wisdom says that CPs are needed to ensure that the AF and metering work with modern cameras.
Well, with the K10D, LPs work just fine.
I can't vouch personally for the K100D. But maybe worth a little investigation before assuming that received wisdom is completely accurate.
ChrisA is offline   Reply With Quote
Old 06-20-2007, 06:16 PM   #10
Arpe's Avatar
Gallery Photos: 10
Yes get a polariser.
A linear works with my *istDs too.
__________________
Member 53 - K20D - Go the Hurricanes!! www.chainsawphotos.co.nz
Arpe is offline   Reply With Quote
Old 06-20-2007, 06:54 PM   #11
I have the Singh-Ray 67mm LB Warming polarizer. It pretty well lives on my 16-45. I used it with a step-up ring on my Tamron 70-300. It only exacts about a 1.3 f-stop penalty.
dndavis is offline   Reply With Quote
Old 06-20-2007, 08:31 PM   #12
wow guys, thanks for the quick reply =). I'll do some research on these suggestion!
__________________
Old 06-20-2007, 08:58 PM   #13
stewart_photo's Avatar
While it is nice to see that a linear polarizer works with your particular camera and lens setup, I have yet to see a single camera, lens, or filter manufacturer recommend linear polarizers for modern cameras. Instead, they all recommend circular polarizers, perhaps based on the notion that while a linear polarizer _MAY_ work without problems, a circular polarizer _WILL_ work. Given that, and the tiny difference in cost between the two types, it seems almost absurd to continue to recommend linear polarizers for modern cameras.
stewart
stewart_photo is offline   Reply With Quote
Old 06-20-2007, 09:08 PM   #14
Peter Zack's Avatar
Gallery Photos: 61
stewart
Absolutely right. You would also want a CPL for lenses that do not have IF or maybe you want to reduce the intensity of the polarizer in certain shots without removing the polarizer each time which is a slow process with a hood in place.
__________________
- Yousuf Karsh
Old 06-20-2007, 09:50 PM   #15
mattdm's Avatar
Gallery Photos: 8
I haven't done a comparison myself, but as I understand it, linear polarizers inherently have a stronger effect.
mattdm is offline   Reply With Quote
