04-12-2008, 10:24 AM   #1
Gallery Photos: 7
Urgent studio help
I bought studio equipment but have no idea how to go about?Camera(K10D and istDL) settings, should i use Manual etc?I bought elinchrom 500 lights x 2, with umbrellas.Where do i start?The lights are wireless, needs to be triggered from the camera's build-in flash or external flash.I have no idea what the settings on camera bodies should be.I really want to learn about studio photography.Any help will be appreciated.Thanks.Gerrie.
GerrieDup is offline
04-23-2008, 12:39 PM   #2
LDB
I just returned from the bookstore. I don't recall titles but there were several that dealt with exposure, lighting etc. so I'd suggest a trip to the local library, bookstore or online bookstore and then a few days of serious reading. Good luck.
LDB is offline
04-23-2008, 12:53 PM   #3
you bought elinchrom's w/o knowing how they work? you're kidding, right? :-)
Run your camera in manual and get a long sync cord. Or buy some pocketwizards to run wireless, but you still have to run manual w/ studio strobes...
kenyee is offline
04-23-2008, 01:31 PM   #4
You need to keep the camera in manual mode. The lights should have built in optical slaves. You only need directly connect the camera to 1 light via sync cord or radio slave. you use the optical slave on the 2nd light to fire it. P-TTL will not work with studio lights.
A sync cord is the cheapest and easiest to use to start out with. You need one with a PC terminal on one end and a Elinchrom terminal on the other, and it should be a long cord. You will also need a PC to Hotshoe adapter. A cheap generic one will work fine.
A trip to the library or bookstore for a basic lighting techniques will also be helpful. The neat thing about digital studio, is you can experiment, and adjust lighting and exposure to your hearts content, and it won't cost you a dime. Just experiment, analyze, adjust, post questions and examples here, and I am sure there will be plenty of people willing to help you out. Good luck.
roscot is offline
04-23-2008, 01:32 PM   #5
Here's a link that might be helpful
http://www.elinchrom.com/Downloads/G...g/Craig_EN.pdf
Set camera to Manual. The shutter speed almost doesn't matter as long as it's at or slower than your camera sync speed (1/180s for the K10D). I'd recommend you get a hotshoe safe sync. This will protect your camera from voltage surges and provide a PC sync socket. Get an Elinchrom sync cord. Attach the sync cord to your main flash, slave the fill flash. If you want to work wirelessly, the Elinchrom Skyports are a great alternative to the more expensive Pocket Wizards, and the less expensive (and less reliable) Ebay radio triggers. The last thing you want to do is trigger your studio flashes from an on camera flash.
I'm not an Elinchrom rep, but I used to sell it in a previous life.
Groundloop is offline
04-23-2008, 06:43 PM   #6
Gallery Photos: 4
Once you get your strobes to work... here is my workflow when using strobes...
Strobes about 6 feet from the subject, I set my (main) strobe to 1/4 power. My camera on manual, shutter is 1/100, aperture at f11. I then adjust aperture as needed... if it seems under exposed, widen your aperture, if it's over exposed, use a smaller f-stop... though if I need to go wider than f/8, I strengthen my strobes instead (and vice versa if shots are too overexposed that I need to go over f16)... I'd rather my camera is set between f8-16... (I don't use a light meter, hence the adjustments. Sometimes I get it right the first two tries though)
My 2 cents...
leadbelly is offline
04-24-2008, 03:54 AM   #7
WOW! A great link as a quick refresher course on studio lighting.
Thanks,
Brian
calicojack is offline
04-24-2008, 03:58 AM   #8
and
Gallery Photos: 13
Ditto...
Unles their slaves have delay mode then its not possible to trigger them with the built in flash. a sync cord or radio trigger will be needed. an external flash will be able to trigger them though, when put on the camera.
and is offline
04-24-2008, 04:20 AM   #9
Gallery Photos: 32
If you're using Elinchrom, forget sync cables or slaves (old tech) and go and use the Elinchrom Skyport to trigger you flash units. No tripping over cables, no mess, dead easy. I would also suggest getting a good flash meter to check incident meter readings and to measure lighting ratios.
creampuff is offline
05-04-2008, 09:28 AM   #10
Gallery Photos: 7
Thanks!!
Thanks to everone, the library and pratice pratice pratice will do the thing for me.. Got some nice books...
05-04-2008, 03:27 PM   #11
If your Elichroms are wireless, you need the transmitter to attach to your camera, did you get one?
Clicker is offline
