Go Back PentaxForums.com > Photography > General Photography - Techniques & Styles > Lenses and paintball
General Photography - Techniques & Styles Discuss the fundamentals of photography, photographic technique, infrared and macro shooting, and related topics here!
01-15-2009, 01:59 PM   #31
Location: The shores of Loch Ness, Highlands of Scotland
You've got to use someone else's kit.
kerrowdown is offline
01-18-2009, 09:26 PM   #32
I've seen some thick filters that might help, or as someone else suggested, doubling normal filters should do it, if the paintball breaks on the first filter, it will loose to much velocity to break through the second one.
nixcamic is offline
01-19-2009, 12:10 AM   #33
If you are shooting at 300mm why not buy a cheap Tamron or Sigma 70-300mm lens as a throw-away. I've seen them in the UK 2nd hand for as little as £50 (approx $90-$100). Hopefully it wouldn't come to that but if it did take an unfixable direct hit - sell it on ebay for parts as a damaged lens. Someone will probably buy it for more than you paid for it too!
There is a new Tamron on Ebay in the UK at the moment on Buy it now for £78.95: Tamron 70-300mm Di LD MACRO Pentax AF *NEW UK STOCK* on eBay, also, For Digital SLR, Camera Lenses, Photography (end time 07-Feb-09 15:27:12 GMT)
Probably the cost of 2 of these lenses would be less than any specialist protectors.
And I really like my Tamron 70-300mm lens - it gets used quite a lot despite the PF which is fairly easy to correct.
Neil
Neil MacG is offline
01-19-2009, 06:34 PM   #34
haha... well, I do have the Sigma 70-300 as a cheapo zoom bought from Singapore for about $240Sg...
So far I have rigged up an old summer rain jacket using the arm as a the lets protector, and rubber ban to hold the front of the lens; Also used a zip lock plastic bag as a inner lining for the "just in case" situation....
And lastly, lens hood and extra filter lens for the unlucky shots... next tournament will be around March, so I will try to get a few test shots before then...
okitoki is offline
01-19-2009, 06:36 PM   #35
do you look stupid holding the camera rigged up like that now? ;P
Vylen is offline
01-19-2009, 07:16 PM   #36
don't give away the player's position :P
dgsullivan is offline
01-19-2009, 07:31 PM   #37
Now now...
it wont look stupid because it will be in the sub-air field which is like a tennis court, and I will only be laying low on the side line at grounds level taking the shots...
As to giving away the position of the players, well, tourny paintballs is not about hiding and stalking (thats bush ball) so there wont be a risk of giving away the position of the players as its a mad rush towards the middle of the field shooting at each other...
There will be an Australia WW2 game held this weekend for the bushballers that I will be attending... Aussie vs Germany so I will be bringing the P&S as well... hopefully will get some good shots (Both PB and photo :)
okitoki is offline
01-19-2009, 07:37 PM   #38
Gallery Photos: 5
Get a underwater case...
Fl_Gulfer is offline
01-20-2009, 12:05 AM   #39
Originally Posted by Jasvox View Post
I disagree. Looking through the first 10-15 shots on that link, 90% or more could be done as a staged shot, which these could very well be. The 2-3 true "action looking" shots could either be taken from the sidelines with a decent telephoto lens, or could also be staged...what, taking a photo of someone getting hit by a round, or firing their marker in an imposing stance needs to be only at risk of you and your gear?
To each his own and I guess I would follow my own advice and opinion, not necessarily forcing it on anyone else.
Jason
Haha, have you seen the background photo from that website?!?! Thats a UV filter + the front element busted out on something suspiciously like L series glass.
Tighearnan is offline
01-20-2009, 12:51 AM   #40
I know where there's a will there's a way. I shoot airsoft which is similar, though a lot less of a risk due to lower joules of energy given the smaller ammo and no paint. I wear a red feather boa that NOBODY can misconstrue. Rather than run 'embedded' style where you're possibly in direct lines of fire, I'd suggest your best defence is identifying choke points where combat is likely and getting into a position near but aside from these places and sniping shots. This way you are prepared for what is coming and an unlikely target. Sniping isn't always as fun as running with the dogs, but I think if you're there as a photographer, thats the most logical way to approach it.
thePiRaTE!! is offline
01-26-2009, 03:15 AM   #41
If all the already suggested fail, u'll just need to do Keanu Reeves style and dodge them as they come.
Live in the Matrix.
Luciferase is offline
01-27-2009, 10:42 AM   #42
hmmm
would posing the shots be too bad of an alternative?
kristoffon is offline
01-27-2009, 04:18 PM   #43
Gallery Photos: 13
Not as long as you don't tell anyone
Arpe is offline
01-27-2009, 07:54 PM   #44
Gallery Photos: 6
Camera Armor for K10D Review!
Talks about camera armour
Originally Posted by Fireball View Post
Because then you wouldn't be able to get shots like this:
PaintballPhotography
I guess it's sort of thing where you do it 'just because you can'
Some damn fine shots in that collection.
I'd get camera amour AND an underwater housing
KrisK10D is offline
01-27-2009, 10:44 PM   #45
Yep, seen that photo before That Canon 28-300 ook a hit to the UV filter. The filter shattered but amazingly the front element was unscratched (!) and after the paint was cleaned off, there were no ill effects of the hit (other than the author having to invest in a new filter).
Let me scrounge around for that photo...
http://photography-on-the.net/forum/...ad.php?t=86465
Fireball is offline
