Go Back PentaxForums.com > Photography > General Photography - Techniques & Styles > Flash vs. camera exposure compensation
General Photography - Techniques & Styles Discuss the fundamentals of photography, photographic technique, infrared and macro shooting, and related topics here!
08-22-2009, 03:59 PM   #1
I have a new Pentax AF-360 flash and the manual is useless. So, I thought I'd ask a question here:
What is the difference between setting exposure compensation on the camera in the usual way when taking a flash picture and turning the dial on the flash to set exposure compensation on that. Does the camera's exposure compensation also increase or decrease the flash by the same amount? Does the flash's exposure compensation affect the camera? When would you use either (or both)?
Thanks.
jms698 is offline
08-22-2009, 04:10 PM   #2
Ash
Gallery Photos: 100
Apparently so.
Camera EV affects flash output as does FEC.
So conceivably, one can achieve up to +4.0 stops of extra flash output (limited to flash's capabilities of course), but dialing +1.0 in Camera's FEC, +2.0 in Camera's EV, and another +1.0 in the flash unit's output compensation...
Ash is offline
08-22-2009, 05:27 PM   #3
With only one flash, the end result will be the same. When you are using multiple flashes, you can vary each flash output individually with the flash on board compensation. If you use flash compensation on camera with a multiple flash set up, you can only change the depth of field, not the flash to flash ratio.
flyer is online now
Camera Exposure Compensation with Flash With camera in Manual Mode jrforman Camera and Studio Accessories 0 09-11-2009 11:03 AM
My camera doesn't show Exposure Compensation FinCanPhoto Pentax DSLR Discussion 16 05-19-2008 11:30 AM
Flash Exposure Compensation Question roger.hayslip Camera and Studio Accessories 4 02-28-2008 08:25 AM
540 FGZ + K10D flash exposure compensation WMBP Pentax DSLR Discussion 12 12-06-2007 05:26 PM
Does *ist DS Have Flash Exposure Compensation? Ole Pentax DSLR Discussion 0 09-07-2006 10:22 PM
