Go Back PentaxForums.com > Photography > General Photography - Techniques & Styles > How do you focus?
General Photography - Techniques & Styles Discuss the fundamentals of photography, photographic technique, infrared and macro shooting, and related topics here!
View Poll Results: How do you focus?
Full Auto focus 9 3.96%
Center point and recompose 119 52.42%
Select the focus point 56 24.67%
Manually focus 43 18.94%
Voters: 227. You may not vote on this poll
09-17-2009, 01:09 PM   #16
I also started this one about a week ago:
Focusing technique
Contains links to other related threads that describe the errors that can occur when recomposing.
JamieP is offline
09-17-2009, 03:30 PM   #17
Centre and recompose, using AF button for focussing. Often use quick shift for subtle adjustments.
NickC is offline
09-17-2009, 03:34 PM   #18
Location: The shores of Loch Ness, Highlands of Scotland
Only got manual lenses.
Bit of clue wich one I voted for.
kerrowdown is offline
09-17-2009, 04:05 PM   #19
I leave the camera on focus select, there's no point not to. If you want the center point it takes two seconds to select it, and the auto point selection is kinda useless (on a K10).
junyo is offline
09-18-2009, 08:06 AM   #20
Center point/recompose 90% of the time. I will use select focus point when taking night shots with a tripod--easier than having to re-level the camera
T_MB is offline
09-18-2009, 09:11 AM   #21
Gallery Photos: 15
I'm actually split about 50/50 between center/recompose and manual, but the former seemed a more appropriate answer in this context.
Marc Sabatella is offline
09-18-2009, 09:18 AM   #22
smc
I usually use older glass so it's almost always manual ...which I still center point + recompose.....
smc is offline
09-18-2009, 09:46 AM   #23
I use all of those techniques when appropriate (or when it strikes me to do so, whether appropriate or not ), but I voted center point and recompose since that's how I focus probably 60% of the time.
heliphoto is offline
09-19-2009, 07:51 AM   #24
Gallery Photos: 11
I've been doing something new (for me).
Shooting my son's soccer games, I find a lot of times kids will run in front of the frame and throw off the autofocus. Even if I have a point picked, the action happens so fast I have to go manual to keep the focus from going in and out.
So I've been using my K200D with "Auto" selected for the focus points but the switch set to MF - then whenever any of the points come into focus they light up. It seems to be working pretty well so far. (of course that doesn't work for A or prior lenses, only autofocus lenses can use all the focus points)
khardur is offline
10-12-2009, 12:04 PM   #25
When AF, I focus center and recompose. Otherwise, manually.
ludenticus is offline
10-12-2009, 12:26 PM   #26
Gallery Photos: 9
Carry-over from film days
When using autofocus, Center Point autofocus and recompose, but I disabled shutter half-press for focus and use the Autoficus button on the back of the camera. Thus the focus behaves as a film camera would.
For Lacrosse I use AF.c and a selected autoficus point (bottom center) to focus on the thighs for a full-body shot. Watching the belt line through the lens allows me to anticipate where the player is going to move and using enough DoF the face and stick head should be in focus..
Most of my lenses are MF and most of my shots are MF, so I set up the camera to favor MF and change as necessary.
monochrome is offline
10-12-2009, 12:58 PM   #27
How do I focus???
By examining some of my shots..."not very well"
but since that is not a choice, I voted for center and recompose. Although I do some manual focus too...
mark
forensicscientist is offline
10-12-2009, 01:21 PM   #28
As I shoot almost exclusively with manual lenses, my answer is obvious.
raymeedc is offline
10-12-2009, 01:39 PM   #29
Dom
How about, all of the above.
Dom is offline
10-12-2009, 04:19 PM   #30
With my AF lenses I almost always set the focus point. But all the listed methods are used depending on the situation.
Fritz is offline
