Originally Posted by audiobomber
I don't remember anyone but you ever saying that a K100D has better noise performance than a K20D. What NR setting are you using with the K20? I use Weak, and I can see a clear difference at high ISO, in favour of the K20. My testing (RAW file, NR off, same processing, compared at same size) shows a 2/3 stop improvement over the K100DS.
Well, I've seen a least one other person (Alfisti?) claim that they like the results from the K100D better, too.
Normally, I tend to suspect people thinking the K100D (or some other 6MP camera) beats some other camera in the noise department are making the mistake of comparing images at different sizes (eg, by comparing at 100% for cameras with different pixel counts). Also, it's pretty common to be fooled by looking at comparisons between entirely different scenes with different lighting and different exposures - all of which can *completely* trump differences between cameras. There can also be differences in JPEG settings, in how any given RAW processor happens to handle one camera versus another, and perhaps even sample variation between cameras. And it can be hard to factor in how well one camera "cleans up" versus another, versus how well they do in a defult conversion. So it's a lot harder to get a really good objective comparison that it might seem.
But in the end, there is also an element of subjectivity in the perception of noise, so when someone who basically knows what they are dong and has both camera in hand and can perform comparisons any way they see fit says they like one better than another, it's tough to argue the point.
FWIW, though, just a couple of days ago I was processing some images from my wife's K100D after having been using my K200D pretty much exclusively for the last year or more. I was actually kind of shocked at just how poor the ISO 1600 and 3200 shots from the K100D were in comparison to what I've become accustomed to from the K200D. Viewed at full screen size with no NR applied, they looked about the same, but since there was significantly less resolution in the K100D images, I really had a much harder time cleaning them up without destroying too much detail. This was most obvious in pictures with faces in them that were relatively small in the frame. There just wasn't enough resolution to allow me to preserve the kind detail in the faces I wanted while still getting the level of noise reduction I wanted and know I can get from my K200D.
Of course, this is all in line with what I often say when this type of discussion comes up. I say I was "shocked" in this case because when I've done direct comparisons in the past, I had always come away feeling they really really quite similar, with the K200D advantage in resolution just *barely* outweighing the fact that with smaller pixels, it shows higher noise at 100%. Here, it was the magnitude of the difference that caught me off-guard.
I think a lot of it has to do with having learned exactly what PP settings to use with my K200D to get the results I want. The K200D has quite a lot of chroma noise and relatively little luminance noise to my eyes; the K100D seems to be the opposite. And I find I can easily clean up chroma noise in ACDSee Pro 3 with almost no adverse effect on detail, whereas it's much harder to clean up the K100D's luminance noise without sacrificing some of the already lesser amount of detail it starts with. So I have the sense the K200D allows me to "keep" most of my 10MP while cleaning up the noise, whereas with the K100D I can't keep as much of its 6MP.
But that's all based on how I go about processing my images; someone else looking at from a different angle might see it differently.
Of course, I realize I'm talking about the K200D, not the K20D, in this comparison. but my sense is that the K20D > K200D > K100D in this sense.
