To fulfill the promise, here is the
Sony E 35 mm f/1.8 vs Sigma E 30 mm f/2.8 (first version) comparison.
Due to the fact that for some time w in possession of both lenses I decided to compare them, as the focal length entitles them to be frequently used by Nex owners.
First of all I would like to emphasise that in no way this is a professional test - at the most "consumer test" or the experience form using, enriched with some technical elements.
Please forgive me my poor English and feel free to correct me where I went wrong :-)
Initial Observations
The comments that you will find below are mine and totally agree with them ;-) However, I put quite a lot of pictures too, so you can draw your own conclusions.
All photos were taken with the Nex 6 as it is the only Nex which currently have.
The tested Sigma is the first version, which, however, is said to be optically identical to the version A (second).
I tried to produce samples as similar as possible, but due to different focal lengths, and my lack of experience, I didn't quite succeed . I just hope that the differences are irrelevant for the purposes of such a comparison ...
The sample photos, except from the ones in "Sharpness", "Chromatic aberration" and "Flare control" sections have been more or less processed (in-camera or in LR/PSP). You have to live with it
Most of the images have the EXIF information preserved.
You can find full-sized files here:
http://bez-lustra.pl/sample/sigma30f28e/ :
http://bez-lustra.pl/sample/sel35f18/ 1. Build quality
Both lenses are relatively small and fit my Nex 6 very well.
Sony seems more solid, it's also a bit heavier. In general, when you keep it in your hand, you get a feeling of a good old analog "fifty" of age of "metal + glass".
Sigma is a bit more "plastic fantastic", but its build quality is also decent. Some flaws: it's possible to block the focusing ring just by holding the lens too firmly; in some copies (and indeed in the one I had) you can actually hear the diaphragm working; a special feature of these lenses is "tapping" inside that stops when the lens is mounted on the body and ready to work.
Sony is a tad longer than the Sigma, but the difference is less than 2 mm. It's also ca. 6 mm wider. Weight: Sony - 155 g, Sigma - 135 g
Pictures of Nex 6 with Sony E 35 mm f/1.8:
Pictures of Nex 6 with Sigma E 30 mm f/2.8:
2. Sharpness Center of the frame
The set-up:
And the comparison:
Bottom right corner
Full frame (from Sigma):
Sigma Sony My comments:
At first glance, Sigma seems to be a bit sharper at the same aperture values - but in my opinion this is due to a slightly higher contrast and a bit warmer image it gives. After a gentle contrast correction in post-process, this impression disappears.
I recognize that both lenses are equally sharp. A few more words on Sony and photos with apertures <2.8: wide open, this lens is a little bit soft, but for me absolutely usable. For safety reasons, however, I mainly set the aperture to f/2.0.
3 Chromatic aberration
Pictures:
Comparison of
Sony and
Sigma Sony @ F/2.0: My comments: Sigma wins hands down here. Unfortunately, CA is a weakness of Sony, we can be sure to find it on the contrasty edges at least up to f/ 4.0. It's not being corrected by the camera in JPG and sometimes it can be extremely difficult (or even impossible) to remove it in post-process.
4. Flare control
Pictures only from Sony 35 mm f/1.8 My comments:
Both lenses generally control the flare decently, preserving good contrast and colors. However, I was able to force the Sony to produce flares without any problems. Unfortunately I was in possesion of Sigma too shortly to check it properly and I don't have any samples :-(
5. Autofocus In this case it's a tie - both lenses have a similar focusing speed and accuracy, taking into account a wider aperture of Sony, of course. In good light the lenses do not have any problems with proper focusing; in low light conditions, though, it's no longer the case and the percentage of misses increases.
6. Bokeh
For obvious reasons, Sony has an advantage here (
in my opinion, of course) – it openes wider
and has a slightly longer focal length, which allows a bit nicer background blur.
Sigma Sony 7. The WOW! factor
In this case, the assessment is subjective of course and for me Sony was a much better choice.
The focal length suits me better and I take a lot of pictures of my daughters mainly in my apartments, in low light conditions. The reproduction ratio is also a bit better (1:6.6 vs 1:8.1). The question is: is it worth paying ca. 3-4 times more for Sony just for the reasons above? Well, for me it was, but you have to make your own decisions :-)
8. Sample Photos Sigma Sony
Please feel free to comment and ask any questions.
