Go Back PentaxForums.com > Photography > Pentax Beginner's Corner Q&A > Would a CPL filter improve these shots?
Pentax Beginner's Corner Q&A New to Pentax or Photography? Post your questions here and get quick answers!
10-31-2009, 07:48 PM   #1
I used to have a polarizing filter many years ago, but never quite got the hang of it. Would this first shot be improved by one? This was taken just about straight into the sun with a DA* 50-135 with a Marumi DHG Lens Protect filter on it. It was a bright, sunny day with a few scattered clouds. About 3:30pm.
What about this one? Same lens and roughly the same time. The sun is at about 45 degrees to the right. I'd like to be able to reduce the haze. This is a major crop of the original.
Thanks,
Richard.
RichardS is offline
10-31-2009, 07:55 PM   #2
Ash
Gallery Photos: 100
Hi Richard. My short answer is yes. They both would have come out more saturated in the blues and the distracting glare would have been largely eliminated. There's more to it, though. Typically the CPL doesn't magically deepen all blue in the sky and cannot cut out all reflections - depends a lot on the incident light and the CPL orientation, much of which is above my head in the technicalities.
Hope this helps.
Ash is offline
10-31-2009, 07:57 PM   #3
Gallery Photos: 10
Yes--the first one especially.
dadipentak is offline
10-31-2009, 08:07 PM   #4
Thanks, guys. I think I'll have to get one and experiment.
RichardS is offline
11-01-2009, 12:16 AM   #5
Gallery Photos: 155
Don't get a cheap one, do some research and get a good one.
Damn Brit is offline
11-01-2009, 01:06 AM   #6
Thanks, Gary. There was a link here somewhere to Polarizing filters test - Introduction - Lenstip.com where the Marumi DHG Super Circular P.L.D 72 mm and the B+W Slim KSM C-POL MRC 72 mm were equal #1. I've gone for the Marumi DHG Super Circular P.L.D (67mm of course for the DA* 50-135). I pulled the trigger on one this afternoon Marumi DHG SUPER Circular Polarizing CPL Filter 67mm US - eBay (item 400080203449 end time Nov-18-09 23:24:04 PST) for USD63.99 including delivery. It seems like a good price.
Regards,
Richard.
RichardS is offline
11-01-2009, 04:33 AM   #7
Ash
Gallery Photos: 100
It should do you well Richard.
I have one of those for my 12-24, and it has proven to be quite a virtue for my landscape shots.
Ash is offline
11-01-2009, 05:35 AM   #8
Light from the sky is polarized only in directions perpendicular to the sun; therefore, the cpl would not change the relative sky brightness significantly in either case.
Light reflecting from water at shallow angles is polarized so some of the specular reflections from the water would be reduced in the first photo.
Some of the haze you refer to in the photos might be a result of strong UV light, in which case the polarizer might help and might not - it would depend on the UV transmission characteristics of the particular polarizer....many polarizers transmit fairly well in the UV as evidenced by a bluish tinge when crossed....in which case they wouldn't help much.
Dave in Iowa
newarts is offline
11-01-2009, 12:47 PM   #9
Thanks, Ash. I'll try it out on the 50-135 first. If it improves things, I'll start equipping my other lenses.
Thanks, Dave. It's going to be fun experimenting.
Regards,
Richard.
RichardS is offline
11-01-2009, 01:40 PM   #10
step-up (or step-down?) rings are your friends, or at least they are mine --- one filter adapted to many lenses, versus a filter for each
xixco is offline
11-01-2009, 01:49 PM   #11
Gallery Photos: 11
Regards,
Richard.
Thanks for the link
Jonson PL is offline
11-02-2009, 10:28 AM   #12
This thread reminds me of a question I have been meaning to ask... how do you measure a lens for a filter? I have never seen a filter in action nor ever had one.. Sounds like a good thing to get though, probably a CPL
Ccat is offline
11-02-2009, 11:08 AM   #13
measuring for filter...
Easiest way it to look at the end of the lens...generally around the trim ring there will be a measurement....something that says: 49mm, or 52mm etc. Thats the size of the filter you need to buy. It screws right into the threads at the end of the lens.
mark
forensicscientist is offline
11-04-2009, 04:33 AM   #14
Gallery Photos: 15
mark
And sometimes, depending on the lens, there is a circle with a line going through it diaganally before the size of the filter (49mm ,52mm etc).
res3567 is offline
11-04-2009, 08:08 AM   #15
Gallery Photos: 92
Remember, do not purchase a cheap CL-pol filter. Such thing would kill the fine rendering of your 50-135. BW Käsemann filters are of super quality. Hoya digital pro1 is okay as well.
Maffer is offline
Hoya CPL Filter Repair merengue Everything Else 1 10-12-2009 05:23 AM
How to improve my bird shots? Tristar Post your photos! 4 09-22-2009 09:24 AM
[EXPIRED] 62mm Hoya UV Filter;62mm Visico CPL Filter Bramela Expired Listings 3 07-31-2008 12:05 AM
cpl and nd grad filter dtra Camera and Studio Accessories 1 07-18-2008 10:10 AM
A couple of things I'd like to improve in my shots Tom Brown Pentax DSLR Discussion 39 02-16-2007 10:22 AM
