| Hi,
The Pentax AF200T seems to get some good press around here. It will work in "Auto" Mode, of which there are two, one for shorter ranges and the other longer. If I remember rightly if you are in Tv mode it will set the camera to the correct F stop when used in either of these modes. It also has fully manual mode, with 4 levels of luminance, which is apparently handy if you get into the off camera flash scene (strobist?), I have some triggers on order to try this out myself.
The AF200S is fine too, but only has 100% flash in manual mode.
Colin. |
