Originally posted by dAIA Can Leon and Lowell share more details on using AF500FTZ with K7? I am about to buy AF500 for 91 USD only if K7 can get more (TTL, zoom sync, etc) out of AF500 than K10, K20.
You should get the AF540FGZ if you are using the K7. I have not had time to play with the AF500FTZ and the K7 but unless there is an undocumented feature in the K7 it should not work, but will only expose at full power or in manual mode, as it does on my K10D.
The reason I keep the AF500FTZ is to use with my *istD which DOES support TTL and P-TTL flash. It is a great flash to use with my K300F4 and other Manual aperture lenses. It also has a shorter flash duration than the AF540FGZ because it was designed around the PZ-1 which had a 1/250 flash sync, and a shorter dwell period for full open shutter.
