Originally Posted by Peter Zack
What do you use? If you have V2's how reliable are they and if not, how often do they misfire? Any other strange things or advice about them? I know I shouldn't go cheap but at $ 45.00 for 1 transmitter and 2 receivers, It's hard to compare the costs when any of the others are going to run $500 ++ for the 3 parts.
I use them. No misfires on their own, but I find they do not quite work at a sync speed of 180... have to dial it down to 125. Batteries do not seem to be the issue here.
Also the receiver shoe that I have is pretty tall. It causes a lot of undue leverage on things. It will tilt so you can aim your strobe, but it is not the best arrangement in the world, and I just know that one of these days the strobe is going to bash itself face-first against the stand. The version I have is an 8 or 16 channel version of this:
Wireless Flash Trigger for Canon 580EX 430EX 550EX - V2 - eBay (item 370049621419 end time May-14-08 02:23:36 PDT) This is the receiver I would avoid.
If you are going to get a set of these, get the receiver that plugs into an additional shoe. here is the set I'd get
Wireless 16 Ch Radio Slave Flash Trigger x 2 Receivers - eBay (item 350056967206 end time May-10-08 08:57:07 PDT)
To use the latter, you will need an adapter for the shoe. I was turned onto these by someone here:
FlashZebra.com: Female Hotshoe to Miniphone Jack (female) (Item #0067) Looks like they are out of stock, but I am sure there is something comparable on eBay.
There are a few advantages to going with this setup... 1. batteries in receiver are standard AAA, and therefore easy and cheaper to keep up with. 2. The receiver is not tall and problematic with respect to having to cant it forward and risk damage to your strobe and/or the shoe on your stand. 3. These triggers will work well with any standard studio strobe you currently have or may get in the future, thereby extending their utility. There are other advantages I am sure.
Another thing... I have a radio remote for triggering the shutter, and it seems that the two do not play nice together. In normal mode with the v2 and remote, when I trigger the camera, no flash. Nothing. I find this more than annoying. The workaround: If I set the shutter release to 2 second timer, and the V2 fires (at 125) every time.
Overall, I'm not too hot on those units. The price is good and they are functional to a point, but frankly I would only buy them as a bridge KNOWING that I am going to upgrade when time and funds permit; if I had it to do again, I'd go with the mini-jack receivers.
Kind regards,
woof!
