Go Back   PentaxForums.com > Pentax Photography > Pentax Camera Accessories
Pentax Camera Accessories Talk about tripods, flashes, memory cards, photo bags, and other accessories for Pentax here!
Old 02-23-2007, 01:30 PM   #1
hmcfly's Avatar
Sto-Fen Flash Products
Has anybody used these? I'm looking for a defuser for my af-360.
This site sells them and want to hear reviews. I find that my flash is to strong even if I bounce it so I'm hoping this will soften it up a bit.
STO-FEN Products
__________________
If a man is alone in the forest is he still wrong?
hmcfly is offline   Reply With Quote
Old 02-23-2007, 01:38 PM   #2
jfdavis58's Avatar
Gallery Photos: 14
Most diffusers work fairly well; Sto-fen are considered very fine! But expect to do some new learning to match the new exposure curve.
__________________
John
jfdavis58 is offline   Reply With Quote
Old 02-23-2007, 02:24 PM   #3
You may want to consider using a bounce card. Here is a how-to video for constructing one from a foam sheet and how to use it. I've just started to play around with one I build per the video.
YouTube - How To Make A Better Bounce Card
Tim
atupdate is offline   Reply With Quote
Old 02-23-2007, 03:40 PM   #4
Each type of diffuser has different lighting effect. Sto-Fen works quite well in some circumstances.
But the best part about Sto-Fen is that it is compact, small and robust. Quick to put on, or it can be left on at all times; compared with LightSphere or bounce card which can be unwieldy and attract unnecessary attention/comments when in use, and fiddly to store and to put on.
nosnoop is offline   Reply With Quote
Old 02-24-2007, 04:33 AM   #5
I occasionally use sto-fen white omnibounce. It comes handy when I don't want direct flash but can't bounce from ceiling but still want somewhat diffused light. It acts like a bulb, lighting up everything in all directions and bouncing from every side. Usually turning down flash exposure to -1 will give nice results and flashing from an angle without bouncing gives a good compromise between direct flash and bounce. Especially useful when you can't bounce - for example when shooting under the tables/benches (well, you can find intersting things there) or trying to catch something deeply situated in shelves, cupboards etc.
aabram is offline   Reply With Quote
