12-12-2007, 10:15 AM   #1
Using K10D with external strobes
I am having trouble using my external strobes (Alien Bees B800) with my K10, due to the lack of a PC terminal on the camera. I first bought the least expensive hot shoe adapter I could find (don't remember the name) and it wouldn't even fit on my camera's hotshoe! Next, I went to the local camera dealer and spent waaay too much on a Wein Hot Shoe to Hot Shoe Safe Sync, and it fit and worked for about half a shoot, and then failed to fire with the camera, and I know it's not a cord issue, bc the flash unit still fired when I pressed the test button on the Wein. Then, I borrowed another, more basic adapter from a friend and it did the same as the Wein - worked for about half a shoot then quit, but unlike the Wein it will still occasionally work, but I really need something more reliable.
I have most recently been using my on camera flash as a trigger, but that is not always possible with the lighting set up I want, and sometimes I would like to use the B800 by itself. The only hotshoe adapters I can find on the internet that claim compatibility with the K10 are for using the Pentax flashes and work with 5 pin cords, not pc cords. I was able to find a Pentax Hotshoe Adapter 2P, which is stated to work with SF, PZ and ZX series cameras. Does anyone know if that will work with the K10? I have been considering a radio slave hot shoe sync adapter, but before I sink any more money into this issue, I would like to hear from anyone who has successfully figured this out. I know I can't be the only one with this problem, and any help would be much appreciated!
12-12-2007, 06:13 PM   #2
After same issue with cheap hot shoe adapter and cord i decided to get this cheap ebay radio triggers. Weak part they have limited range 10-15 ft and work for sync speed 1/125s and slower. Best part they are cheap and cost for pair less then 1 pentax adapter.
Best solution would be get some pocket wizards, they are expensive but worth it.
12-12-2007, 06:42 PM   #3
Your best bet would be some sort of wireless trigger system. In my opinion, you have 3 choices.
The Gadget Infinity 16 Channel Studio Strobe Triggers
Elincrhom Skyports
And of course, Pocket Wizards
Ive also listed them from least to most expensive.
Edit: and some interesting reading perhaps. poocs.net — Elinchrom Skyport vs. PocketWizard
12-13-2007, 05:13 AM   #4
I had the same problem. I purchased the Alien Bees radio flash trigger transmitter & receiver and couldn't be happier. It works perfectly.
AlienBees: Remote Controls, Wired and Wireless Remotes for your Flash Units
12-13-2007, 07:50 AM   #5
All of my studio and off camera flash experience is decades out of date. I assume the Gadget Infinity units have to be used in X or M mode of the K10D since there is only one pin on the transmitter's shoe. Is that correct?
12-13-2007, 09:27 AM   #6
Hi Mike,
As far as I know, all the radio triggers are non TTL, and only have the center firing contact.
12-13-2007, 09:34 AM   #7
If you can find some place that actually has this in stock you might try it.
Pentax | Hot Shoe Adapter 2P | 31014 | B&H Photo Video
Radio triggers are much more convenient though. I use PWs, after being totally frustrated with cheaper units. Be aware though, that even with high quality triggers, you might not be able to sync at the full 1/180th shutter speed. I can go to 1/125 with my PWs, but at least they are consistant.
12-13-2007, 10:28 AM   #8
PW does not have problem with sync at 1/180, 1/200, 1/250
thats why im getting them today
12-13-2007, 05:34 PM   #9
Not trying to start an argument with you or anything, but have you tried them yet? The best I've been able to do with my Bowens units is 1/125. Please let me know if you can sync faster with your Alien Bees. I may have a problem with the camera or my flash units.
Just out of curiosity, how do you intend to sync at 1/200 or 1/250 when the camera's top sync speed is 1/180.
12-13-2007, 06:31 PM   #10
QuoteOriginally posted by roscot Quote
I use PW on ABR , AB800, AB400 and AB Zeus several times. No problem with sync 1/180 on my Pentax. Also with higher speed on other brands cameras, nikon D200 (1/250) and Canons 30D, 20D, 40D. (here sync speed vary depend from model)
I never said pentax can sync flashes on higher speed, i just said PW can.
12-13-2007, 07:18 PM   #11
Alien bees has wireless triggers that work well.
12-15-2007, 05:30 AM   #12
Hmm, my units must have a longer response time to the signal. re the sync speed, sorry, I misunderstood you.
12-18-2007, 10:36 AM   #13
I went to a shoot on Friday the 14th and the studio had both the Gadget Infinity units and 2 different kinds of Pocket Wizards. Both worked flawlessly on my K10D at 1/180sec sync. 1 set used dual Alien Bee B800 and PWs on channel 1. The second set used a single Alien Bee 400WS and the GI control. The third set used 2 Elinchrome flashes (didn't notice the model) and PWs on channel 4. The only problem I had was the fact that since there were sometimes 4-5 photographers working simultaneously with the same model on the each set, we occasionally stomped on each other's shots (blank screen of oblivion). Overall, I shot approx 500 shots switching back and forth between the 3 sets without any problems. Photos will be posted soon...
12-18-2007, 05:27 PM   #14
Thanks, everybody! That's exactly what I needed to know. I think I'm going to go with the Alien Bees, and I am very happy to be able to do so with confidence.
Thanks again - I'm so happy I found this forum!
Asking for External Flash Recommendation for Pentax K10D Wild About Fowl Pentax Flashes and Lighting Technique 4 05-19-2010 07:57 AM
K10D and external Flash What am I doing wrong? Michael Rothman Pentax DSLR Discussion 59 08-01-2008 09:31 AM
K10D and pc connection to strobes smokey Pentax DSLR Discussion 8 10-08-2007 02:22 PM
K10D and pc connection to strobes smokey Pentax DSLR Discussion 0 10-06-2007 09:40 AM
External flash for K10D JeepJockey Pentax DSLR Discussion 5 03-16-2007 02:23 PM
