05-26-2010, 06:23 PM   #1
Error with Pentax k-x
ever since I have gotten this camera I have gotten the message about 15-20% of the time. "This Image cannot be displayed" I am using a Centon SDHC class 10 4gb card and I have about 6 of them and the error has happened on all of these as well as a class 4 samsung SD card. not sure if its the cards or the camera or what. i have reformatted the cards through the camera and have deleted all the media a few times and the problem persists. Anyone have any ideas on this matter? is there a firmware update or anything to fix this?
05-26-2010, 06:25 PM   #2
Hate to state the obvious, but were the images you were trying to view taken with the same camera that they were being viewed on?
05-26-2010, 06:35 PM   #3
Yea I would take a picture go to look at it and it would give me the message or sometimes I would take a few pictures and all of them would have the message.
05-26-2010, 06:38 PM   #4
Might be a problem with the actual card, then. That message is only shown when there are errors in the file!
05-26-2010, 06:43 PM   #5
But its been like 6 or 7 cards. You really think so?
05-26-2010, 07:02 PM   #6
enoeske's Avatar
I can't find any mention of Centon's card speeds. They don't mention it on the website, likely for a good reason. My guess is these are cheap cards with bad transfer speeds and can't keep up with the frame rate of the K-X.
Try shooting 1 shot every second. Probably no errors.
Try shooting in continuous mode holding down the shutter release. Probably a few errors after a few seconds.
see reviews here:
Amazon.com: Centon 32GBSDHC6*32GB CLASS 6 SDHC Flash Memory Card (Blue):…
05-26-2010, 07:05 PM   #7
xjx
Try a quality card and if the symptom persists your camera has hardware problem. I don't think it is related to firmware because your situation is the first I have heard of.
05-26-2010, 07:07 PM   #8
I've received this error when I deleted specific images from the card via the computer and then reinserted the card into the camera. No big deal. I just delete the error images through the camera.
Edit: Actually, I think it happened when I cut and pasted certain images from the card to another file on my computer. Maybe the "Cut" leaves a residual file or something like that.
05-26-2010, 07:08 PM   #9
Hmm my girlfriend uses the same cards and has never gotten this problem but she uses a canon rebel t1i. Do you think its still the cards? If so Ill buy a bunch of new ones now but I dont see how hers work perfectly and mine crapped out
Oh also it has class 10 on the card itself not sure if that matters
05-26-2010, 07:37 PM   #10
kiwi_jono's Avatar
I must admit I have seen something similar. I have a AData class 10 card. Most of the time it works well and I notice a reasonable performance improvement over my other card (class 6) for continous shooting.
However occasionally I see the "Can not be displayed" error and when I download the image to the PC (Using USB not a card reader), the image is indeed corrupt.
I'm not sure of this, but I think this has mostly happened when I have turned off the camera too quickly after shooting a bunch of shots. I have recently been careful to not turn off straight away and so far have not seen any corrupt images.
05-26-2010, 07:42 PM   #11
Well, I'm just tried to reproduce the error with cutting and pasting the images from my card reader on my pc to a file on the pc but it didn't work this time. However, I do know that in my case it was directly related to this as it was only a few specific images that I remember cutting and pasting. Then, when I was reviewing images on my camera, I kept getting that error message. I realized it was exactly those images I had cut and pasted. Perhaps it was from removing the memory card from the reader without "safely removing hardware".
05-26-2010, 07:56 PM   #12
Upgrade you firmware.
Take most recent one from Official Pentax JAPAN site (as they have most recent updates and are doing some silent updates)
Latest K-x Firmware Update : Software Downloads : PENTAX
05-26-2010, 11:29 PM   #13
I just checked and I am already up to date in firmware. Maybe ill just give Pentax a call and see what they have to say
05-27-2010, 02:47 PM   #14
happend to me many times when u edit image in comp, sometimes there's enough if u just adjust something in picasa or so, and camera is not able to read that anymore...however, card in comp allways works so it's more like k-x can't read what it didn't made than card issue
05-27-2010, 05:44 PM   #15
Senior Moderator
Parallax's Avatar
Format the card in the camera and see if you still have the problem. If you do, it doesn't necessarily mean that it isn't a card problem, but it eliminates other possibilities.
camera, card, cards, class, dslr, error, photography
Memory Card Error! Pentax K10 D kriss15 Pentax DSLR Discussion 22 07-21-2011 07:39 AM
Pentax k-x '' card error '' message crossing Pentax DSLR Discussion 4 01-13-2010 01:17 PM
PLease help! - 'memory card error' on Pentax K100D Ophelia Pentax DSLR Discussion 2 10-01-2009 03:13 PM
Pentax Optio E10 Start error XHouser Pentax Compact Cameras 2 12-04-2008 03:45 PM
Pentax Error Kills :) barbosas General Talk 15 08-23-2008 11:56 AM
All times are GMT -7. The time now is 10:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
