Pentax 540 Flash, K10D and what hot shoes adapters to get
Pentax DSLR DiscussionTalk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
Hi all,
I will be purchasing the Pentax 540 flash in the next day or so and was wondering about some of the Pentax accessories that can go with it in partticular the hot shoe adapters.
What advantage will these provide and what are their main functions. Here are the links to the BH Photo page with the respective products.
also, will it be worth my while to purchase the extension cords as well? For alot of the stuff I do i dont need a flash, however when i do need it i have been using a Sigma EF430ST with some good results
All this gear has got me a little confused. The main thing for me is to have a top notch flash with an option to do some wireless flash photography. Thats all.
I'll be watching this thread since I'm expecting my 540FGZ to arrive in the next day or so. I'm hoping to use it in wireless TTL for macro shots, but without having all the pieces together to play with reading the manuals doesn't really help me. I was 'out' of photography quite a while (my last system was a Contax RTS II) and the only way to get off camera TTL was using cords. There's obviously been a lot of advances in technology since then and I'm having to play catch up!
This is an excellent thread below that should answer those questions. There's limited use for the cables and if you are mainly concrned with wireless, you might want to wait for now.
The flash works beautifully in wireless mode, with the caveat that you have to use the on board flash to trigger it. So if you are not comfortable with having the flash expose from your camera as well then you better buy a hot shoe adapter. I have really enjoyed mine though and it works extremely well.
The onboard flash can be set to only trigger the remote flash, and not contribute to the exposure. See custom option "Flash in wireless mode" on the K10D.
I would recommend using the wireless flash and forget about the cables and adapters for now. They are only useful if you have specific needs.
If you do decide in the future that you need the cable, you can use the adapter FG and F5P cords. Adapter FG allows you to use built-in flash at the same time (adapter F would block the pop up flash). AF540 has direct plug in for F5P cord and you do not need a off camera adapter (required for AF360FGZ). Another option is the promaster flash cord.
Shooting in wireless mode, I am able to set the flash (540FGZ) to "auto-zoom" -- but as far as I can tell, the flash doesn't actually do any zooming. For example, I just tested with the Pentax 16-45 on my K10D, with the lens zoomed to 45mm. The flash unit (wireless, slave) showed P-TTL and auto-zoom, but the focal length shown was 16mm. This was the case even after I took the photo. NOTE: You would probably NOT expect the zoom to show the right focal length until you press the shutter, because it's the pre-flash signals that send info to the flash.
On the other hand, just connected the 540FGZ by cable to the K10D and took the same shot -- and as soon as I press the shutter down half way, the flash knows the focal length....
My 540FGZ arrived today and I have to say I'm pretty impressed with it. Wireless TTL and being able to trigger it without the pop up flash contributing to the final exposure is bordering on magic as far as I'm concerned.
It's not all perfect though. Like Roger and Will, the auto zoom doesn't work wirelessly on mine either, but since I'll be mostly using it off camera only for macro/close up work, that's not a big deal.
