11-04-2007, 10:47 PM   #1
k100d stop-down metering problem
K100D with SMC-M 50mm/1.7.
I know how to work the manual lens, but noticed a weird problem with stop-down metering in low-light conditions.
in "M" mode, I first tried the DA 18-55 lens metering in a room lit by a 100W bulb. I tested f5.6-22 aperture range and the exposure metering came up with speeds from 0.3sec-6.0secs (f22/6.0 secs)
Now, with the M 50/1.7 lens with stop-down metering, I got the following results:
f5.6 - 0.3 secs
f8.0 - 0.7 secs.
f11 to f22 - all get 0.7 secs when stop-down metered.
So, above f8.0, the metering is wrong.
Have you experienced the same problem?
Regards,
Stan
11-05-2007, 12:34 AM   #2
It is normal. It is actually a problem with stopped down metering. When the user stops down the aperture of the lens, the TTL metering light sensor receives less light than when it is wide opened.
In your case, you shot in an already low light situation. After stopping down further, at some point, the light metering cell simply cannot "see" anymore which is called to be "out of the metering range" (for this case, it is out of the lower limit). In case of wide opened metering mode, there is a warning to tell the user that the lowest metering range has been reached and the sensor is unable to measure further, but in stopped down metering, there is no aids and indication to tell the user that, for the current Pentax's design.
Do note the primitive problem of stopped down metering is still the light loss caused by teh aperture cut which cause even more troubles to take the metering readings in low light conditions.
QuoteOriginally posted by stanjo Quote
f5.6 - 0.3 secs
f8.0 - 0.7 secs.
Regards,
Stan
11-05-2007, 07:47 AM   #3
code4code5's Avatar
From f11 to f22, was the ".7" indicator in the viewfinder blinking? It should if it's outside metering range and that's what I've found with my manual lenses.
11-05-2007, 11:44 AM   #4
RiceHigh, what you describe was exactly what I though too.
What confused me, though, was the lack of warning - no blinking indicator in the viewfinder when the stop-down metering failed.
If Pentax fixed the stop-down metering warning indicator, I wouldn't have a problem with this.
But its very misleading to have an indication of successful metering with bogus values.
Thank you all.
regards,
Stan
11-05-2007, 12:37 PM   #5
Finn's Avatar
Oh, I doubt it's all that conspiratorial. Besides, why would anyone shoot at f/22 in a darkened room anyway?
camera, dslr, f8.0, k100d, lens, photography, secs, stop-down
stop down metering? jonhock Troubleshooting and Beginner Help 8 01-01-2010 04:00 PM
K-x Stop-down metering with m-42 lenses Bazwell Pentax DSLR Discussion 8 11-20-2009 12:57 PM
problem with K100D ... no matrix metering kmccanta Pentax DSLR Discussion 6 06-08-2009 10:24 AM
stop-down metering and Av mode Beau Pentax DSLR Discussion 15 06-02-2009 09:58 PM
f-stop and metering wiseman Troubleshooting and Beginner Help 6 03-10-2009 08:00 AM
All times are GMT -7. The time now is 09:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
