Maybe this has been answered already - Does the K20D have some method where the user can input a focal length multiplier for when a teleconverter is in use?
One small thing that frustrates me is how SR capability of my K10D is degraded with a teleconverter - The camera thinks a 300mm lens is attached (Tamron 70-300 at the far end) when it's actually a shade under 450mm (1.4x TC). I have yet to find a way to override lens FL for lenses that report a FL to the camera - and it would be much easier to just have the camera calculate it automatically.
No. A solution is to use an "A" teleconverter, which doesn't transmit the focal length to the camera. In this case you can dial in the FL yourself. Which, of course, is quite inconvenient when using a zoom.
Hopefully the announced Pentax SDM teleconverter will multiply the focal length.
Perhaps there is: Pentax (Hoya) wants you to buy new tele converters!
Unfortunately it is an undefined function in the KAF and KAF2 mounts.
Since it is undefined, they could simply address it, in the same way they could address the K10D Metering issue for Manual apature lenses, the solutions are easy nad only software.
What really gets me is they go our of their way to advertize that the camera will function with every lens they ever made, and yet there are fundamental errors, where it does not function as it should. The teleconverter issue is one, the exposure for K10D and manual lenses is another.
They need to make the cameras work in a reasonable manner, otherwise they will loose credibility as a maker
How exactly does the lens transfer focal length data to the camera? Is it a digital code of some sort, or an analog signal? I would think that either could be intercepted by a properly equipped TC and either recoded (if digital) or multiplied (if analog) somehow.
Wouldn't putting a bit of tape over the electrical connectors covert the lens to an M-lens, therefore allowing you to enter manually? I have never tested this, and of course it takes away a lot of the features of the lens, but could potentially allow you to take a photo.
You could enter a teleconverter factor in the SR menu just like you can enter focal lenghth of older lenses. A really simple solution.
That wasa the solution I proposed over a year ago.
All TCs for AF pass the lens focal length and focusing information through the 7th contact on the K Mount (furthest away from the lens locking pin) and therefore you cant block this data or AF does not work correctly. BUT a simple menu, for a TC correction factor, either at boot up or through themenu screens, function button or what ever would fix the problem for good.
