Originally Posted by kmccanta
What is the equivalent lens on my K100D to a pair of 8x25 binoculars?
Does the viewfinder magnification change the answer? whats the equivalent on the K10/K20?
how do I figure out what the view through 12x36 binoculars will look like in camera terms?
There are several different calculations involved here. The first is that the binocular magnifies the view by a factor of 8 (in the example given). A lens "magnifies" the view proportionally to the diagonal of the viewfinder frame, which is considered to be 1 X. The diagonal of a 35mm film frame is about 43mm, of the APS-C sensor on a Pentax dSLR, about 28.4 mm. Just to throw something else at the equation, 35mm normal lenses tend to be 50-55mm rather than 43. To get 8X magnification of the distant image, one would need a (28.4 X 8 =) 227.4 mm lens. However, if you are attempting to get an 8X view through the camera viewfinder, you will need to add in the 85% reduction, and use a lens of (227.4 / .85) = 267.5 mm.
Just to throw another wrench into things, the field of view of the binoculars may be wider than the camera lens' field of view. They usually do have a wider field of view, but for a premium, one can get an even wider field of view.
Just some musings while recovering from a migraine headache in the Rocky Mountains.
