Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > bad banding with k20d
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
05-19-2008, 04:25 PM   #1
today my k20d started generating this vertical banding on a lot of pictures. Totally random it seems. Have anyone seen this before or know what it could be??
I shot on iso 100-200 and using short exposures too. And it was RAW/DNG...
any ideas??
debbie is offline
05-19-2008, 04:30 PM   #2
Gallery Photos: 171
any ideas??
Check your SD card download speed. How long have you had the camera. That looks like a TV screen.
benjikan is offline
05-19-2008, 04:36 PM   #3
I´ve had it for 5 days. The SD card speed should be 6mb/sec (if that is what you mean) And yes, it looks like shit!!
debbie is offline
05-19-2008, 04:41 PM   #4
Try another SD card and card reader and if you still have issues, send it back. The only way you would normally get that sort of pattern is from high levels of radio frequency interference. This can come about because of a poor contact in the camera or poorly applied shielding or a very old mobile phone or you live next door to a sub-station!
Is it just the one shot or all of them?
*isteve is offline
05-19-2008, 04:44 PM   #5
No it is several shots, They came in groups. Like 4-5 in a row and then it disappeard for like 30 shots, and came back again.
The bands were visible already in the camera.
debbie is offline
05-19-2008, 06:41 PM   #6
Most likely a defective sensor, I'd get a replacement.
ricardobeat is offline
05-19-2008, 10:13 PM   #7
Gallery Photos: 21
Ricardo,
How were you able to narrow the fault down to the sensor and not some other factor?
Obrigado
PK
Peacekeeper is offline
05-20-2008, 12:13 AM   #8
Does the problem appear only in raw photos or in Jpeg as well (if it does not occur in both chances are it is not the sensor)
Can you see the lines on the camera's display screen or only after you download the images to your computer. (could be bad cable or software issue)
Is the battery at full or near full charge?
Did you try formatting the memory card to make sure that its file structure is not corrupt. (6Mb/sec sounds like a slow low end memory card, with a K20 I would suggest that you get a fast card to handle the large image files, something closer to 20Mb/sec)
I would be interested to know what you find out
spyglass is offline
05-20-2008, 12:43 AM   #9
so far its only in RAW it appears. Its visible in the camera display and the battery was not fully charged.
The SD card was formatted once. And about the SD card, its a san disk ultra II so it works with 15mb/sec.
I took several shots today and nothing appeard yet. I took out the card and the battery and put it back in. Maybe it was some kind of bad connection issue. Anyway I will go on and see if it appears again.
Yesterday it kept coming several times so...
I let you know
(and thanks for the answers!!)
debbie is offline
05-20-2008, 01:07 AM   #10
Location: the Beautiful Okanagan, in British Columbia Canada
If you got the card through an on-line store I'd almost bet that it's a fake
And the fakes have been known to cause many similar problems.
little laker is offline
05-20-2008, 01:51 AM   #11
Gallery Photos: 171
Since the camera is new....Send it back to avoid any doubts you may have. That is what I would do.
Ben
benjikan is offline
05-20-2008, 02:19 AM   #12
Gallery Photos: 6
I think it is an sd card problem, not camera
Jaleel is offline
05-20-2008, 03:31 AM   #13
jdg
How would an SD card cause this kind of problem?
jdg is offline
05-20-2008, 03:41 AM   #14
Easy, quick way to prove or disprove the SD card may be at fault is to swap it out and take about 100 shots and see if the problem persists.
If it is evident with another card, send the camera back and get a replacement.
Jason
Jasvox is offline
05-21-2008, 03:05 PM   #15
changed sd card
yes, it was the sd card. I changed it to a 5 year old kingston card. Check out the difference!!
the same settings on the camera with a 30sec exposure
100% view detail...
the old kingston
and the new card
debbie is offline
