Go Back   PentaxForums.com > Pentax Photography > Pentax DSLR Discussion
Pentax DSLR Discussion Talk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
Old 06-17-2008, 12:57 AM   #1
jms698's Avatar
Don't update to the 1.01 firmware! It breaks autofocus
I just updated my Pentax K20d to the 1.01 firmware. However, now my 16-50mm f/2.8 lens no longer focuses. It makes a loud noise whirring noise and hunts to either end of the focus range. It sounds like it is trying to even force the lens to focus past the extremes of the focus range with the motor grinding when it reaches the end of the focus range. After hunting like this for a few seconds it gives up, failing to focus properly. This occurs in all lighting conditions. Previous to installing the new firmware there was no problem and the lens focused perfectly.
I wonder if there is a way to downgrade back to the 1.0 firmware?
In any case, I would suggest everyone hold off upgrading to the new firmware. It obviously hasn't been tested properly.
__________________
www.deltaflow.com - Hare Krishna
jms698 is offline   Reply With Quote
Old 06-17-2008, 01:17 AM   #2
I just checked my K20D and DA 16-50 after your post and it's operating properly. Camera was upgraded to ver. 1.01 earlier today.
No idea why your lens is acting like that. I hope you get it resolved .
Terry
Tyama is offline   Reply With Quote
Old 06-17-2008, 04:21 AM   #3
I just my K20D and DA*16-50 also after seeing this post. AF worked fine. I upgraded early yesterday morning.
agchang is offline   Reply With Quote
Old 06-17-2008, 04:59 AM   #4
Have you contacted Pentax UK to see if they can help? n/t
There is no text, why force me to enter some characters?
__________________
RiceHigh
My Pentax Blog: http://ricehigh.blogspot.com
My Homepage: http://www.geocities.com/ricehigh
RiceHigh is offline   Reply With Quote
Old 06-17-2008, 05:36 AM   #5
benjikan's Avatar
Gallery Photos: 151
Just tested firmware V 1.01 on my three K20D bodies. The 16-50 works as it should. Perfectly.
Ben
benjikan is offline   Reply With Quote
Old 06-17-2008, 05:42 AM   #6
Ben
How many 16-50 lenses have you tested then? If it is also 3, then there are 9 combinations!
p.s. Just admire you so much for having so many K20D bodies and that must be Great!
__________________
RiceHigh
Old 06-17-2008, 05:49 AM   #7
benjikan's Avatar
Gallery Photos: 151
It is OK...Having six bodies takes up quite a bit of room though. That is 3 K10D's and 3 K20D's. I think I might get seven more to make it a "Bakers Dozen"
Old 06-17-2008, 05:57 AM   #8
I don't have the 16-50 so can't comment but my lenses work fine. Have you tried cleaning the mount contacts on the lens and the body and then reseating the lens? 1.01 does appear to "break" Bibble. Dave
__________________
DA10-17 DA14 DA21 FA31 FA43 FA77 M135 FA*200 F*300 Viv S1 105/2.5
davef is offline   Reply With Quote
Old 06-17-2008, 07:01 AM   #9
Lowell Goudge's Avatar
is it possible that you have a bad contact between camera and lens? If it is hunting like this it suggests that the data for focusing distance is not being fed back to the body as it should.
check and clean the furthest contact away from the lens locking pin, use a pink or gum erasor, not abrasive.
Lowell Goudge is online now   Reply With Quote
Old 06-17-2008, 07:12 AM   #10
Maybe, but unlikely, I guess. It might be that the new firmware is not fully compatible with some different versions of the hardware including the body and/or lens.
My advice is if problem persists, just contact the Pentax UK's for servicing or technical support. I think his lens and body are both under warranty.
Sometimes those firmware upgrades could create new problems, so if it is not really needed, don't do the upgrades.
__________________
RiceHigh
Old 06-17-2008, 08:15 AM   #11
You're making rush conclusions
Have you tried to put your lens on another Pentax body with SDM support? Did it work?
Have you tried to put another Pentax SDM lens on your K20D? Did it work?
I am 99% convinced that this is just coincidence.
__________________
Edvinas
Edvinas is offline   Reply With Quote
Old 06-17-2008, 08:38 AM   #12
ChipB's Avatar
Gallery Photos: 4
There's a chance the firmware got corrupted while doing the upgrade - I'd suggest re-doing it.
__________________
Chip B
Pentax user for 40 years!!
ChipB is offline   Reply With Quote
Old 06-17-2008, 09:05 AM   #13
vievetrick's Avatar
Gallery Photos: 28
I am going to say this as nice as possible,
Come on Rice the chances are way more likely that it is the contact and not the firmware.
__________________
____________________________________
Pat B - I have nothing interesting to include in my signature
vievetrick is offline   Reply With Quote
Old 06-17-2008, 09:23 AM   #14
sad thing he does... no matter how many facts there are. Problems not so much him but the fact that a true problem can get ignored because of the normal reaction to just blow off his babble (yes I'm guilty).
And no matter the cause it's always Pentax's fault.
I updated the firmware on two bodies last night, and just tried my lenses.
They all seem to work fine. My 16-50 2.8 is focusing without any issues.
elliot
jeffkrol is offline   Reply With Quote
Old 06-17-2008, 09:46 AM   #15
Just spring out of my room to test my 16-50 and 50-135.... all is good...
Was kinda worried when I read the post.
Anyway, hope you have a chance to check the contacts and let us know your progress.
__________________
Pentax K20D, K10D, K100D(SOLD) + many lenses.(LBA issues ) ... AF, Adaptall, M42, M39
www.flickr.com/photos/koala78
http://picasaweb.google.com.au/mcjm78
mcjm78 is online now   Reply With Quote
