Go Back PentaxForums.com > Pentax Cameras > Pentax DSLR Discussion > TR Power Pack III Batteries -- NiMH ???
Pentax DSLR Discussion Talk about Pentax Digital SLR modes, technique, operation, and problems here (K and *ist D series).
02-11-2007, 02:07 AM   #1
Hi All,
Does anyone know if NiMH batteries can be used in this high voltage pack for the AF 540 FGZ? The owner's manual specifically says that you cannot use NiCads (as do the instructions for the TR2).
Scott
snostorm is offline
02-11-2007, 07:07 AM   #2
on the instructions of the 540, it said you cannot use NiMH's too.
i was kinda dissapointed to read that
-=edit=-
it's weird, i just went on the pentax website to look at the 540, and it lists NiMH as a usable power source, contrary to what the instruction manual says.
-=JoN=- is offline
02-11-2007, 02:35 PM   #3
My manual says otherwise. On Pg 4, it said you could use alkaline, lithium or NiMh batteries.
nosnoop is offline
02-11-2007, 05:11 PM   #4
you know what, i just re-read it, and i misunderstood what it said.
you are right, it will take Ni-MH's
thanks for the clear up
-=JoN=- is offline
10-21-2007, 10:03 PM   #5
Yes I know this is back from the dead but..
He wanted to know whether you could use C size NiMH batteries with the Power Pack which is available for the 540fgz flash.
And so would I. I found some C nimh's that are perking at 5500mAh. [could you EEMAGYN? ]
anomaly is offline
