Go Back   PentaxForums.com > Pentax Photography > Pentax DSLR Discussion
Pentax DSLR Discussion Talk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
Old 07-20-2008, 10:29 AM   #1
K10D Soft or OOF?
Please take a look at this picture and let me know what you think about the sharpness, softness, focus of this picture? I've had this camera for 6 months now and have yet to get a single sharp photo. I am at a loss on what else I can do to improve my photos.
PS EXIF data is intact.
innershell is offline   Reply With Quote
Old 07-20-2008, 11:43 AM   #2
Unfortunately, it appears that meta data is stripped by the server.
What lens, aperture and shutter speed in this example please?
It's quite likely that you either have a back focus/front focus problem if you are using AF.
Have you tried careful manual focus to see if you can resolve the sharpness problem that way (if this cures it, you have an AF problem).
Also, what are your image settings? If everything is set to low contrast/soft, etc, then you will need to do some post processing.
Wheatfield is offline   Reply With Quote
Old 07-20-2008, 01:39 PM   #3
EXIF
Camera: Pentax K10D
Lens: Pentax SMC-FA 50mm 1.4
F-Number: F/8
Exposure: 1/100
ISO: 100
Metering: Spot
Mode: Aperture Priority
Camera Settings
Saturation: 0
Sharpness: +2
Contrast: +1
Old 07-20-2008, 02:14 PM   #4
EXIF
Camera: Pentax K10D
F-Number: F/8
Exposure: 1/100
ISO: 100
Metering: Spot
Camera Settings
Saturation: 0
Sharpness: +2
Contrast: +1
I guess most of the K10d softness is due to front focusing or back focusing. Because many people report "sharper" after focus correction. Just a guess, I do not own K10d.
ckanthon is offline   Reply With Quote
Old 07-20-2008, 02:26 PM   #5
EXIF
Camera: Pentax K10D
F-Number: F/8
Exposure: 1/100
ISO: 100
Metering: Spot
Camera Settings
Saturation: 0
Sharpness: +2
Contrast: +1
Check for front focus or back focus. At f/8 that lens is razor sharp.
Old 07-20-2008, 11:11 PM   #6
Mine all looked like that for 6 months too. I sent it in to Pentax and they fixed it. All I said on the report to the repair facility was that it had a considerable back focus problem. After fixing, the images are much sharper. I would even say, "sharp".
I would suggest you send it in. I'm pretty sure that's what you've got going on (back or front).
Kent!
ksignorini is offline   Reply With Quote
Old 07-20-2008, 11:16 PM   #7
Kent!
Thanks Kent. How long before you got your camera back? It's festival season in Edmonton and I'd hate to lose my camera for the next 2 months.
Old 07-21-2008, 06:13 AM   #8
I know all about festival season in Edmonton!
I bought it at McBain and took it to them. I believe they sent it to Alta Camera in Calgary who then either repairs it or sends it to Pentax Canada. I've now dealt with Alta Camera in Calgary on a couple other occasions and repairs are faster if you send directly to them (you can find their contact info online).
I think it took about 3-4 weeks to get my K10D back, even having gone through McBain first. Unfortunately, Pentax repairs aren't the fastest (you are usually told it will be 6-8 weeks on the outside).
Good luck! Like I said, don't be afraid to contact Alta Camera directly by phone--they will probably give you a timeframe estimate if you ask. I know for fact that McBain sends to them first (saw the whole report from McBain to Alta on another repair).
Kent!
Old 07-21-2008, 09:10 AM   #9
Before you send it for calibration (takes 6 to 8 weeks as people mentioned), take a look here and try to test it for back/front focusing by yourself. You might be surprised by the fact that some of the picks are soft due to your own error. At least I was...
Here the links some goop fellows recommended to me:
1) AF adjustment test chart to help with the Pentax K20D Custom Setting No.34 - Digital Cameras - Zimbio (explains how to fold the chart)
2) PART-1. Autofocus Adjustment for the Pentax K20D, Custom Setting No 35 - Digital Photography - Zimbio
3) PART-2. Autofocus Adjustment for the Pentax K20D, Custom Setting No 35 - k10dbook - Zimbio
Try that first, then make your decision. If you want to know what my dilemma was see this blog: Front focusing while wide open???
Good luck!
x_goal is offline   Reply With Quote
Old 07-21-2008, 09:22 AM   #10
I wouldn't use thart chart to check focus. It contains too many lines, so if your AF sensor is not exactly where the red dot is in the viewfinder, it will still find something to focus on, so you never really know what you are focusing on. Yvon Bourque has a new set of targets dthat are much better to check for front/back focusing. Just look for Yvon bourque blog spot to find them.
flyer is offline   Reply With Quote
Old 07-21-2008, 09:34 AM   #11
x_goal & flyer: Thanks for the info. I will be doing extensive testing today with the links you sent to ensure that it is indeed the camera and not the cameraman. For 6 months, I have been assuming it is the cameraman and with no signs of improvement, I am obviously starting to blame the camera.
I am now shooting in RAW as I seem to get the sharpest picture with it.
Old 07-21-2008, 10:00 AM   #12
You should take a look at the all links first, then make comments!!!
As I wrote, the first link - with an old chart - just to see how to fold and assemble the whole thing. Second and third links - the links to parts 1 and 2 of an article about a new AF checking chart developed by Yvon Bourque...
Summary: read first, then comment....
Old 07-21-2008, 12:17 PM   #13
I sent my K10D in to Pentax Canada three times so far this year, and the turn around was no more than 14 days.
Just some FYI for you
Dave
__________________
Equine photography in York Region
K10D istD PZ-1 SF-1 SP500 SP100 SP K1000 6X7:
D1, D1H, D2H, D200:
http://www.caughtinmotion.com
http://brooksinthecountry.blogspot.com
pentkon52 is offline   Reply With Quote
Old 07-21-2008, 04:06 PM   #14
Sorry if I ruffled a few feathers, but I was at work and got sidetracked before I could see all the links. So, I apologize for not taking the time to look properly before posting my answer.
Old 07-21-2008, 04:23 PM   #15
x_goal: I'm glad you posted those links I had posted in your original problem post. I didn't have them handy.
Kent!
