Go Back   PentaxForums.com > Pentax Photography > Pentax DSLR Discussion
Pentax DSLR Discussion Talk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
Old 08-06-2008, 06:42 AM   #1
K200D Autfocus Problems
Yesterday when I tried to take a picture with my Kit lens the camera could not autoocus. It makes a wizzing sound but the focus ring does not even move. Is it a common problem? Is it that I am not attaching the lens correctly. i made sure to connect the red dots and attach it.
Thanks for your help.
josekj is offline   Reply With Quote
Old 08-06-2008, 12:59 PM   #2
madbrain's Avatar
What were the lighting conditions ? Was it very dark or indoors ?
If so, try to pop-up the flash and see if autofocus works.
__________________
K200D, Pentax 18-250mm, Sigma 10-20mm, Digital concepts 952AF/PEN flash, JJC remote control, tripod, Opteka right angle finder
madbrain is offline   Reply With Quote
Old 08-07-2008, 06:46 AM   #3
Well I played with the kit lens to make sure it was completely in place and then took the picture and it worked. I think some loose contact. It was indoors and the room was fairly dark.
Old 08-07-2008, 08:05 AM   #4
Answer
Very probably the AF screw couplers (male and female) were not in position and thus not coupling well. The body screw was just dwelling the mount so you just here the wizzing sound.
To avoid the problem, mount your lens gently and don't overshoot. Stop once you hear the click sound.
To re-produce the problem, press the lens release lock and mount your lens, try to mount by turning to the extreme end (where there is some plays after the click position if you don't press the lens release lock) or just a little bit incomplete but the electronic contacts (pairs for the body's and the lens') are still in contact. Then you will see the same problem again.
__________________
RiceHigh
My Pentax Blog: http://ricehigh.blogspot.com
My Homepage: http://www.geocities.com/ricehigh
RiceHigh is offline   Reply With Quote
