Go Back   PentaxForums.com > Pentax Photography > Pentax DSLR Discussion
Pentax DSLR Discussion Talk about Pentax Digital SLR technique here, including the *ist D series, the K100D series, and the K10D, K20D, and K200D models.
Old 08-07-2008, 02:46 AM   #1
k20d auto ISO in TAv mode
Hey all,
My k20d is set to use ISOs from 100-2000 in auto mode, but when I'm in TAv, it'll often stop at 1600, even though it tells me that 1600 is too slow. Stopping down often gets it to jump to 2000, which it also deems as too slow. My question is, since I'm shooting in low light and might just be willing to live with it being underexposed, is there any way to get the camera to give me that extra 1/3rd stop of help by jumping to 2000?
Will
__________________
PENTAX k20d | DA* 16-50mm/2.8 | DA ltd 21mm/3.2 | DA ltd 40mm/2.8 | DA ltd 70mm/2.4
MAMIYA RZ67 | Sekor Z 65mm/4.0 W | Sekor Z 110mm/2.8 W
wiyum is offline   Reply With Quote
Old 08-07-2008, 06:24 AM   #2
tubadad's Avatar
Auto ISO Range
On the K10D you can limit Auto ISO to a range, check this out on the K20D and see if you have set Auto to have a max ISO of 1600. Also, the K10D has an Auto Exposure correction, if you have this as well, perhaps you have to turn it off.
__________________
PENTAX DA 16-45mm f/4 * PENTAX FA 50mm f/1.4 * PENTAX SMC DA 55-300mm f/4-5.8 ED * Pentax AF-540FGZ
http://www.flickr.com/photos/tubadad/
tubadad is offline   Reply With Quote
Old 08-08-2008, 01:36 AM   #3
Yeah, I definitely set the range to 100-2000. I couldn't find auto exposure correction though.
Will
__________________
Old 08-08-2008, 04:53 AM   #4
When set on "B", the camera auto ISO stops at 1600 (page 78 of K20D book). So maybe the electronic try to keep the ISO at 1600 to minimize noise.
flyer is offline   Reply With Quote
Old 08-10-2008, 06:08 PM   #5
Arpe's Avatar
Gallery Photos: 10
I use TAv mode extensively and do not have this problem with my K20D. Sorry. I have it set to 100-4500.
__________________
Member 53 - K20D - Go the Hurricanes!! www.chainsawphotos.co.nz
Arpe is offline   Reply With Quote
Old 08-11-2008, 10:21 PM   #6
I've been curious about TAv...why do you use it and why set at 100-4500...
...in other words, what kind of photo situations are you dealing with this way?
janosh is offline   Reply With Quote
Old 08-11-2008, 11:13 PM   #7
Venturi's Avatar
Gallery Photos: 4
As someone else here explained a few days back, TAv mode is akin to shooting in full manual but switching film on the fly. You manually set your shutter and aperture with the e-dials, and the camera sets the ISO for the 'correct' exposure.
__________________
- Jim
Resident Pain in the Aperture
My Gear
Venturi is offline   Reply With Quote
Old 08-12-2008, 06:56 PM   #8
Arpe's Avatar
Gallery Photos: 10
Taking photos of rugby.
I know what my minimum shutter speed I want is.
I know what minimum aperture I want.
So I set, say 1/500 at f4.5, and let the camera figure out what ISO to use (it's faster than me at that). As conditions can change from second to second (clouds scuttling across the sky etc.) I need something on auto!
With a 3pm kick-off the game finishes at around 4:30pm. In winter, on a dark wet day, it can be very dark by the end of the game. By then I usually would have dialled back the shutter speed to 1/350 or even 1/250, and the aperture to f2.8, but the ISO will still be high.
Why ISO4500? Because it's better than no picture at all.
It's good because I have control over the things that really matter and let the camera do the rest. (I also dial in -0.5 exposure compensation, just seems to need it)
__________________
Old 08-13-2008, 10:22 AM   #9
Thanks Arpe & Venturi... I need to explore this.
I also find N-.5 a good idea .. "N" is usually excessive in my contrasty light...might not be that way in flat light.
Old 08-13-2008, 11:59 AM   #10
On partly cloudy days with quickly changing light and shooting a sports game where you would want a fast shutter and as much depth of field is where I use it. A nice feature.
__________________
reeftool is offline   Reply With Quote
Old 08-13-2008, 06:18 PM   #11
Arpe's Avatar
Gallery Photos: 10
And even on sunny days when the players run from bright sunshine into the grandstand shadow, the camera reacts a lot faster than me!
__________________
