I've never shot in RAW before but will try using it when I go to Mystic Seaport next week. I was wondering if there will be a big difference in image quality if I use 6 verses 10 megapixels? Also, what setting should I use normal, bright or does it make a difference? I don't have photoshop and will be using Pentax's program to convert to jpeg. Thanks.
You can change the bright or natural setting in PPL. Rather than do the first batch as a RAW conversion, just use the "Extract JPG" in Tools. It is much faster with 100's of files, and will give you something to look at and judge what you might want to adjust. I started doing it this way a few batches ago.
I think the Bright, Natural, Landscape makes a difference in certain colors especially green. I have taken a few pictures and looked at the results in each mode. Maybe you should check it out to get an idea. You could also do it.
Check the links below.
Ummm...I shoot RAW for the most part on my K10D and to the best of my knowledge RAW is always 10 Megapixels. That is because RAW is the raw output from the detector and the camera has a 10 Megapixel detector. The option for lower pixel density is limited to JPEG.
Likewise, the image tone, saturation, sharpness, and contrast settings are also limited to JPEG files. (At least that is how I read the section in the manual on page 122. Though the documentation indicates that this information is available to PPL for post-processing. Not so for products such as Lightroom.)
It sort of makes sense...RAW images are what the sensor "sees". You use the RAW converter in post processing (PP) to do the things that the in-camera processor normally does when it makes a JPEG.
Depends on what you're going to be doing to the images too.
6 Mpix is more than enough for web, but if you are even thinking of print - go max Mpix all the time - as mentioned, you never know when you want to crop or print big.
I agree with stevebrot. I think Raw is always capured at 10 MP, and the "in camera" settings (bright;sharpness etc) will have no affect on the raw file.
Hmmm Mystic Seaport... been there. Worthy of the highest possible image quality....
Shoot raw and use a good quality RAW processor to get high quality jpegs, mind you the quality of the RAWs from my K10D are superb and normally all I need is a quick adjustment of levels and you have stunning pics...
Raw is always 10MP (or whatever the max resolution is), and the saturation, color, sharpness, etc settings don't directly affect raw images. However, many raw processors will use them as the "starting point" for how the image will look. I use the Pentax software and that what it does.
